Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 14 1.8%
    Votes: 27 3.4%
    Votes: 153 19.2%
    Votes: 604 75.7%
Back in the day, most amplifiers would get up to 45-50°C internally and still last 30 years. And now amplifiers are supposed to break down at 40°C?
Then there's the old Musical Fidelity A1 which reputedly got hot enough to soften its buttons and knobs if operated in a warm environment, or without enough free space above it. It also used its case as a heatsink. I don't think they'd be allowed to sell something that got that hot these days.
The old Musical Fidelity A1 operated mostly in Class A mode at around 65°C (sometimes even higher) in a virtually unventilated enclosure. This means that all internal components were constantly running at a minimum of 70°C.
For units that were used frequently or continuously, the capacitors required servicing every 6-7 years.
Based on this, a unit operating at 45°C lasts approximately 30 years or more, which has also been confirmed by experience. However, this doesn't take into account the stress caused by the high switching frequency of Class D operation.
The newer Musical Fidelity A1, its successor, operates at normal temperatures but is technically unrelated to the old unit.
Does the Fosi v3 mono overheat like the reviewers say? I'm afraid it will affect the durability of the amp.
And should I buy the version with two power supplies or the one with a single power supply and adapter, which is about $50 cheaper?
And I have a pair of Fosi ZA3 speakers, can I use their 48W power supply with my Fosi V3 mono speaker?
@Fosi Audio Help me.
View attachment 520567View attachment 520566
Mine get quite hot running kef r3 as external amp from denon receiver, hot as keeping your hand on top hurt after a while, i got an ac infinity fan and problem solved.
Something to keep in mind when comparing to older conventional amplifier designs. The older ones had larger enclosures with considerably more internal air volume that changes how heat is disapated. These new Class D chip amps have very small cases and much much less air volume for components to disappate heat into. I am talking about capacitors, inductors, opamps, etc. The amplifier chips use the case as heat sink. The other components do not. The TPA3255 has a thermal protection circuit that shuts it down. The other components do not.
I am an electrical engineer. I can tell you that electrical parts have life predictions based on operating temperatures and how much time spent at elevated temperatures. If you run a V3 Mono at high power levels for a lot of the time, you will shorten the life of the components in it - not just the amplifier chip. That is not fear mongering. That is simply the fact of how electronics react to heat.
If you are going to drive a very inefficient speaker (think Dayton Opal One at 78 dB) and crank the volume, then you should use some kind of cooling fan. For most users, that is not necessary so the need for a cooling fan is what engineers would call an 'edge case'. Most users need not worry.
I bought one of those guns to measure temperature, I had them out in the open and they read 39-40°,then I moved them into an enclosed space, still around 40° - not much change with louder or more dynamic music really - always between those ranges. I would recommend separate power supplies always. Ive stopped worrying now and just enjoy the music - they are silly good for the price!
Is there a significant improvement in sound quality when using a GaN power supply?
As I said - the only benefit is size. There is no audio quality benefit.
I have these deployed for my local Church. They run in a "cabinet" where they sit on a shelf, the cabinet is not locked but it isn't specifically ventilated either and sits in a corner. There have not been any issues with them even during concerts and such, while driving RP-8060FA II speakers at over 60% volume.
I also have a set of these at home driving RP-8000F II and I have played them at ~50% volume for 12+ hours straight without any issues. Touching the amps after this time reveals they are "pretty warm" but I can lay my hand on them without burning it. I haven't checked the temps with my temp gun (good idea) but I would imagine not much over 100F just from my general "feeling". The water that comes out of my sink is way hotter lol, for electronics these are not high temps.
If anyone is looking at this website from a laptop; most modern laptops hit temps of 105C on the CPU under heavier workloads with burst temps over 90C and most don't idle below 40C.
In regards to power supplies; the ones in the church use the individual PSU's and my ones here at home use the combined PSU.... neither gets too hot in my testing.
So anyone who is worried about these in terms of temps and longevity; I wouldn't personally.
I bought three at the kickstarter drop 18 months ago. 2 of the three have failed. On the up side, Fosi quickly and at no charge replaced them. All 3 are now working fine. They sound very good even when not taking price into consideration. At the price point they are incredible. Still, 2/3 failure rate is exceptionally bad.
What were you driving with them to make them fail? I also wonder if it was an issue with the early batch as you said that you got it off of Kickstarter.
Very likely I would say. I am convinced most kickstarter deliveries will come from the first or even pre-production batches. There can be all sorts of manufacturing process issues with those.
On the topic of “over heating”, I’ve not had a problem with the 3 v3 monos I own and I use separate 10amp power supplies.
I did remove the orange mesh from the sides which means I guess I am getting more ventilation.
As I explained to him 10 months ago in a post he "liked" 4 minutes before creating the post #661 above.
There has been a complete change of mindset since the 1950s. From the beginning of a real interest in quality sound reproduction around that time people bought equipment that they intended to keep for a long time. From the 1970s onwards developed a mindset to constantly change and that included just about everything including hi-fi. White papers in the 50s and 60s stated clearly that if temps for components dropped dramatically then life expectancy for components especially caps would increase 2 or 3 times or more. The obsession with manufacturers to create products in as small a space as possible was the name of the game. I reckon that the majority of people on this forum change products quite quickly so component life is irrelevant. Lots of modders pay good money for Z foil resistors (I am one of them) because they will stay within their stated parameters almost indefinitely and are totally transparent. They will ruthlessly expose any distortion that precedes them. There is no secret it's simply their construction is so different to 'standard' resistors.
At the very least use the amps on their sides and remove the 'pretty' copper coloured plates this will allow a convection current to be formed when in use. It also means these amps will take up less space. I also use a computer fan which really lowers internal temps. I first used such a fan long ago underneath a hybrid head amp. Along with a Dutch friend who had the same h/amp we noticed a small change in sound. If your 'belief system' stops you from actually trying that's up to you. Remember - all theory should come from practice.
I 3d printed risers stands for mine, added heat sinks and had a usb 80mm rolling fan on them. When I took them apart to replace the boards fosi sent me the thermal paste seemed correctly applied although it was the cheap kind. I used better thermal paste when I reassembled them. I know they have redesigned the boards as my 2nd replacement had different lower gain level settings for the rca side. I think there is a good chance the 1st ones were rushed to market and they have since worked out some bugs.
I used 4v mindsp flex balanced as my pre/dsp. My speakers were small JBL that are easy to drive. I dont think wother was a factor in the failure
Get separate power supplies. Get some $6 cooling fins and thermal tape and some $5 thermal paste. Problem solved.
Exactly! I 3d printed risers stand for better cooling, had a 80mm cooling fan on them, replaced the cheap thermal paste with good stuff and added a heat sink. Way overkill, but they did not get hot. I dont think my failures were caused by heat.
So then it was likely some design flaw in the first batch. I have nothing at all on either set of the ones that I deployed, not in my house and not at the church and neither has an issue in almost a year now of very regular use.
Or yours happen to have Divine Protection.
