Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 14 1.8%
    Votes: 27 3.4%
    Votes: 148 18.9%
    Votes: 595 75.9%
I had the opportunity to borrow a rega brio-r and I'm currently testing it on my system in place of the v3 monos. This amp was not recommended for my speakers because of its 2x50w only. In general, the measurments are in favor of the Fosi.
And yet, the rega moves easily my speakers, surprisingly as easily as the v3 monos. Actually, the two amps sound very good, but after hours of listening, I can say that the rega "brings me more emotion".
It is the first time I can make this kind of comparaison and until then I was convinced that amp didn't make a sound difference as long as they provide enough power with low distorsion before clipping.
So I'm confused...
I suggest swapping back after a day or two. It’s next to impossible to get the volume levels the same, even if they are otherwise similar, and that will affect your judgment. Knowing Rega, it’s probably got some nice rich distortion products which can be pleasant. On the other hand, they may be inaudible.
What source are you using?
So I'm confused...
Why you're confused? Without a controlled listening, you can get any result. It's perfectly right what you "feel"
Now, do a proper gain leveling and ask for a friend to change the amplifier, without knowing what amp is working, (or buy a decent switcher with remote control) and see what happens.
I'm aware it is difficult to judge without the exact same volume. And I agree Rega probably add its "touch" to color the sound with distortion. Because that is what I feel. I have the feeling to listen to vinyl record even if my source is flac files and streaming service directly from a pc via a dac/pre amp aiyima T8.
At low volume for instance, the sound with rega is fullier, with more bass. The sound is a bit muddier, which makes me push the treble on my preamp. With the v3, it sounds punchier, dryer too, more clarity, highs.
It reminds me the visual effect with the 4k tvs. Without changing the mode from natural to "cinema" (at least that is the name in Europe) , the image is so clean that it is unconfortable. Feels like watching "the young and the restless". We are used to watch movies with filters, with 24 i/sec. It is unatural but our brain is used to it.
I have the same feeling with the v3. It is (too?) clean, kind of too pure. For modern pop electro music it sounds fantastic, but maybe it fits less for 70s rock classics
So I'm confused...
It isn't quite enough to say the amp has to have enough power to avoid clipping and decently low distortion to sound transparent, you have to add that the amp must be designed to have a flat frequency response (i.e. without artificially increased bass or treble) and the amp must be able to handle whatever impedance peaks your speakers thow at it.
That said pretty much any decenbt amplifier should pass those conditions these days (with the possible exception of class D amps lacking post filter feedback which can tend to have a rising frequency response). That means that either your Brio doesn't produce a 'proper' flat response and you happen to prefer that changed sound or, much more likely, it is just your imagination or you haven't set the two amps to exactly match volumes in your comparison. Do a proper level matched blind comparison and it's likely that you won't hear any difference.
I
This way lies madness. You can't go around with dozens of different audio systems so that you can play each type of music you like on a different system that happens to colour the sound in a way you like for that particular music type and the particular time of day and alcohol level e.t.c. you are at. Just get a transparent flat response amplifier that doesn't do any of that crap and then dial in whatever tonal colouring you fancy as a tone control/DSP/PEQ of some sort .
And low enough output impedance for the frequency response not to be altered by the variation in load impedance (see for example Erin's tests with speaker simulation loads relative to pure resistance). And being stable into the load impedance - certain amps in the past were known for oscillating when connected to the 'wrong' sort of speaker or cable. That sort of marginal stability problem may be where the ideas about cables making a difference came from.
So I'm confused...
You'll have to do a blind test and match the volume of your amps before jumping to any conclusions, trust me.
Hello, can anyone recommend which settings to use with Fosi V3 mono for best possible fidelity and clean sound using the RCA input, 19 db or 25 db gain, is there a difference? I plan to use it with my Denon AVR. I also have XLR to RCA cables but I heard contradictory opinions on using XLR to RCA cables. Help will be much appreciated.
You are probably not going to hear a noise level difference between the two settings but to optimise things I suggest simply using the lower 19db gain setting and check if you then have sufficient gain available to reach the loudness you want. If it's not loud enough then use the higher 25db setting.
If you use XLR to RCA you would have to crank the volume up higher so if you feel like doing that, you should just use RCA and set the gain to 25 dB. Even at that high setting, the gain is still 3 to 4 dB lower than the gain of Denon's build in power amps so you have either manually match it with trim settings (assuming you are using the V3 Mono with some of the AVR amps), or re-run autosetup/Audyssey.
I don’t like to contradict you, but surely an XLR output is often at a higher voltage than RCA. Typically 4 volt max versus 2 volt max. If I’m understanding correctly then the amps would be receiving a higher level rather than a lower one, so might match better on the lower sensitivity.
By all means explain where I got this wrong!
No problem contradicting me, but I guess you missed the fact that the OP said he would be using a Denon (presumable an AVR), that has unbalanced output (RCA). So he won't be getting the higher output voltage if the Denon has balanced/XLR output.
You would be right if he uses an AVP such as Marantz's balanced/XLR output.
Even if he uses a RCA to XLR cable, he would still be getting half the voltage, the only benefit of such cable, if it uses 2 dedicated conductors (not including the shield) for the RCA and wired correctly, is to minimize noise, approaching the level of a real balanced XLR to XLR cable, but again it won't get him higher voltage.
Thanks! I read XLR to RCA as implying that was the direction of the signal. But I see now it’s actually RCA to XLR input so that makes sense. :-)
Yes, thank you Peng. I ended up using RCA to RCA cables from my two Fosi V3 mono's to my Denon 6800H AVR. I chose RCA 25 db gain, the levels are more matched and I don't have to crank up the volume so high. By the way, these two little boxes deliver great sound and details for my left and right spaeakrs.
Good to know that it works well for you. "high" is a relative term, in this case relative to the Denon's build in amps. Denon AVR doesn't have balanced outputs (except the flagship model A1H0 so you can use RCA only anyway, and if you use RCA to XLR cable the results will still be the same, you won't get high voltage because the output on the Denon AVR is still unbalanced RCA.
Hey guys, I’m wondering if these can be connected with a passive preamplifer which has only a potentiometer? My concern is that I heard class D amplifiers simply don’t have enough DC protection and with a simple potentiometer combination there are more chances that speakers could be damaged by upstream.
Class D has nothing to do with that, although quality and good design of both the amplifier( whatever class it is) and the other devices might be more relevant . What component(s) are you thinking of connecting to the amp via a passive pre?
Have you checked your existing devices to see if they actually have any DC offset?
You heard wrong. There is no such problem with Class D amplifiers in general. It is specific to the implementation, just as it is with other amp classes.
