jmdesignz2
- Joined
- Aug 19, 2025
- Messages
- 393
- Likes
- 196
Is it correct that the ASR review was done with the 48v/5a supply?
Has it been measured with the 48v/10a supply?
YesIs it correct that the ASR review was done with the 48v/5a supply?\
I am not aware of any measurement by ASR.Has it been measured with the 48v/10a supply?
Keep dreaming!I appreciate that, but everything I'm reading about the speakers suggests they like Class A/B amps, and sound better with them.
There are myths and untruths that have existed around Magnepans forever. "Lots of Power", "Lots of Current", etc.I appreciate that, but everything I'm reading about the speakers suggests they like Class A/B amps, and sound better with them.
In all those things you are reading - what objective evidence is presented for the claims made.I appreciate that, but everything I'm reading about the speakers suggests they like Class A/B amps, and sound better with them.
Looks like this one is with the 10a:Is it correct that the ASR review was done with the 48v/5a supply?
Since that picture is from the test with a 48v/5a SMPS, what would it look like if it was under a 48v/10a?In all those things you are reading - what objective evidence is presented for the claims made.
Measurements? Fully controlled blind testing?
Or is it just the normal talking heads spouting "opinions" based only on sighted listening?
This is what tells you that it will drive your speakers (and pretty much any other) without issue:
Not much different. Even Fosi has said as much in this thread.Since that picture is from the test with a 48v/5a SMPS, what would it look like if it was under a 48v/10a?
That's just it, I haven't made up my mind, indeed I came here looking for exactly the answers I got to let me know I don't need to buy anything else.There are myths and untruths that have existed around Magnepans forever. "Lots of Power", "Lots of Current", etc.
Look at the impedance curve for any Magnepan, and they are all just about the same, from the LRS through the 3.7's, and you'll see it's nearly flat and something in the range of 4-ish Ohms. They are not that difficult to drive from a modern amplifier's perspective. Fifty years ago, with far lesser performing electronics than are available today, amplifiers did have a little more difficulty with that 4 Ohm impedance versus most speaker's 8 Ohm impedance. Amplifiers with tubes as their final stage faired even worse, as the tubes capable of high current were (and still are) not cheap and not plentiful.
No one will talk you out of the Class A/B amp if you've made up your mind that's what you want. Just don't fall into the old, persistent myths trap.
I absolutely believe, like in other cases of "lore", somethings are retold so often they become truth. But as you point out, measurements don't lie.In all those things you are reading - what objective evidence is presented for the claims made.
Power supplies: I remember that I read something like 2 x 48 V / 10 A = 196 Watt @ 1 % Distotion andSince that picture is from the test with a 48v/5a SMPS, what would it look like if it was under a 48v/10a?
You can - but unless things have changed with a single supply you also need a filter to stop interference between the two amps. So you still have two boxes, and therefore no advantage (IMO)You can run each amp with its own 5A supply or use a splitter cable with a single 10A supply for both
Yes, I forgot to mention the filterYou can - but unless things have changed with a single supply you also need a filter to stop interference between the two amps. So you still have two boxes, and therefore no advantage (IMO)
It would indeed enable more current to be demanded by the amp, though my recollection is that it’s very unlikely in practice that would arise with this combination. Possibly on the test bench, however.The pair of amps I have each have their own 48v 5amp power supply. Although each having their own 48v 10amp PS would not appreciably increase the wattage, would it allow for the amp to draw more energy when needed?
