The answer to that is not simple.I’ll be using Wiim Ultra as source which only has RCA out. Would using RCA to XLR cables into the V3 Mono’s offer any improvements? I know the signal would still be unbalanced, however wondering if using RCA to XLR cables could offer lower noise and higher dynamic range, as V3 is rated to perform better with XLR input
First - if you experience no audible noise, then there will be no benefit to connecting to the XLR input.
If you are getting audible ground noise, then XLR will only help if you use an RCA to XLR cable wired as "pseudo balanced" using a 2 wire plus shield cable, with the shield and "cold" wire both connected to the ring at the RCA end, but at the XLR end they are separately connected to pin 1 (shield) and pin 3 (cold). The Hot wire is connected to pin at the RCA end and pin 2 at the XLR end.
Most RCA to XLR cables are not wired this way and it is difficult to identify those that are.
In any case you don't get a better dynamic range, because that relies on the higher voltage on an XLR output - which obviously the Ultra doesn't have.
