Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 13 1.7%
    Votes: 24 3.2%
    Votes: 141 19.0%
    Votes: 565 76.0%
Only 14 of these for my home theatre
I have Emotiva XT3 Towers and XC1 center.
I have a Onkyo RZ70 receiver
I have dual Klipsch RP 1400SW subwoofers.
A review on YouTube said that these speakers need more watts than traditional speakers because they are 4 ohms.
So I looked for amplifiers and found the Fosi V3 Mono. After reading the review it delivers 200w of actual power to the speakers. So with 3 amplifiers I could power my front speakers. Then I became curious about Bi Amping. Most people say it doesn't do anything and some say it helps deliver more clarity. Because Fosi V3 are inexpensive I bought a single Fosi v3 with a 5A power supply and I bought dual Fosi v3 with a 10A power supply to power to blocks.
I plugged the amps in and so far I'm impressed with the sound.
I have a RCA Y splitter from the preouts and then connect to each bi amp port on the speaker.
Two amps are connected to one power supply and each amp is connected to a high frequency terminal and low frequency terminal. The amps then provide 200w to each terminal.
I read that bi amping won't make a noticeable difference. So I'm asking would a single 500w amp sound better then dual 240w amps
Well first - with your dual 240W amps, you are not delivering 480W to the speakers. This is because the power spectral density of music falls off rapidly with frequency.
This means the power into high frequencies is much lower than into low frequencies at the same volume, depending on where the crossover split is between the low and high frequency terminals is. If high frequency dirves only the tweeters, it is likely only needing 10 to 30W with 240W going into the lower frequencies.
If you use a single 500W amp, this means you have much more power available for the low frequencies where it is needed. But this will only deliver better sound quality if you currently need more than the 240W the low frequencies are getting, and the 240W amp is clipping. I very much doubt this is the case, because if it were your sound pressure levels would be in the dangerous-for-your-ears territory, and it also wouldn't be "impressive" sounding.
Very Interesting. I still have some confusion. The RZ70 has a preouts for the front speakers. With a Y splitter RCA cable I can take the signal and make it into two. Each signal going into a Fosi Mono v3. Then each Fosi going into the high frequency and low frequency.
Because it is not active bi amping the speakers have a internal crossover. But each Fosi v3 mono is sending a full signal into each port in the back of the speaker. The speaker then uses the internal crossover to send the correct signal to the speaker.
I think what you are saying is because of the internal crossover even tho a full range signal is going into the high frequency terminal the internal crossover only uses 10-30w so it does not take advantage of the remaining 240w. Where as the low frequency uses all the 240w.
If you had a 500w amp like a NCore Buckeye then the low frequency would have more then 240w to use to make the bass sound better with only 10w to 30w going to the tweeter?
Is this correct?
Because two Fosi v3 mono blocks are connected to one 48v 10A power supply does this cause any sort of issue? I assumed both monoblocks provide the same 200w full range single to each low and high port and it isn't likely the entire power supply is being used so there would be any problem? Sound wise hi res music sounds great. However on some streams I can hear small little single pops and I don't know if it because of the audio track.
I don't want to damage my speakers. I'm considering getting individual power supplies 48v 5A for each monoblock so two monoblocks won't interact with each other. And because I have five monoblocks I might as well passive bi amp right?
Is this correct?
Is this correct?
Pretty much. Though it is not the crossover that causes lower power into the high range. The crossover just separates the frequencies. The lower power for the high frequencies is already built into the full range signal.
No
Most likely due to dropouts in the data stream somewhere, most likely in your house rather than outside it. It could be built into the source file, but if streaming from a service this would be a pretty bad failing.
You can if you like, but it won't make any improvement to the sound - just complicates the wiring.
I got a replacement board for one of my dead V3 monos from Fosi. Working fine now again obviously. Nothing wrong I can see with the dead board though, nothing blown etc.
I think it's misleading that the V3 mono shows up in the ranking at 100 points, but when using RCA it would be at 94.
I recommend to change the ranking to:
V3 mono (balanced) 100
V3 mono (RCA) 94
V3 mono (RCA) 94
I think you’ll find the balanced measurement is used whenever available. It is typically a higher Sinad. It’s not misleading and many of us prefer to use balanced connections.
V3 mono (RCA) 94
you'll need to do that on every amplifier with balanced inputs .. so, i think is simpler to have the ranking with "the best result" as a standard and it's done.
if someone is interested in the details (i'll use rca / whatever), so read the review.
I understand, but if these rankings were in a database, and I'd filter by RCA.. the products would be in quite a different order I guess.
Some devices might even have better RCA implementation than balanced. And I wonder what the market shares are, 90% RCA?
Perhaps closer to 80% overall market share for RCA, but for ASR reader base more like 80% XLR if I had to guess.
Complete guess though.
-Ed
if the better implementation is RCA ... RCA SINAD will be in the ranking ... i don't get your point.
My Nakamichi PA-7 Mkll finally decided to take a time out the other day with a bad soft start circuit, so I decided to try these Fosi's out in the interim.
WOW!!!
Running 2 thru my Nak preamp, 2 10 Amp power bricks pushing the current, making my Montana ESP 2's sound sweet as ever.
Im sold.
WOW!!!
Im sold.
Can you give some info on your 10amp power bricks please.
Voltage,manufacturer, type, andwhere to purchase.
Thank you
Considering a pair of these to mount behind my floor standing speakers, it would be very interesting to see how they get on powering my ATC SCM40 loudspeakers.
Speakers not especially efficient 85dB @ 1m @ 1W
