Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 13 1.7%
    Votes: 24 3.2%
    Votes: 141 18.9%
    Votes: 569 76.2%
The problem with overheating is because the manufacturer sells stands with fans. I think the housing sheet should be pressed in the shape of teeth or a zigzag. The heat dissipation surface would be much larger. Class D equipment should not heat up so much or break down after a few hours. I have an smsl q5 pro amplifier and it has been working reliably with large 4 ohm speakers for over 4 years without a break. It is only slightly warm. That is why I thought Fosi would be newer and better. Too bad, because I liked it
One of my two V3s (latest revision) just died after just a few weeks of using them. It's still powered judging by the LED but no sound at all. Cross checked with the other channel, nothing.
Anyone elses V3s failing yet?
I had the same thing. My Fosi went back to the dealer. They need to improve the design because there are more situations like this.
Until today, mine lasted for almost TWO months...and had a very hot chassis from the beginning...I can say it had a lot of good sounding power...Luckily, was given a refund...
Sad to report that a friend of mine also bought two of those for his desktop system and discovered problems with both. One of the amps had something rattling inside and soon stopped producing sound. There were apparently also irregularities with the second one. They will be going back to Amazon, from what I hear
Ordered mine on August 15th. Got them on the 17th. One had something rattling around and would light up, but no sound. Got it replaced. They have been working great since the 19th of August. They are side by side with a two inch gap between them and I have a small desk fan blowing over them and the cases stay nice and cool to the touch.
They are used at least 4 or 5 hours every day.
I got two of them stacked with a small fan pushing air from the left and another pulling from the right. I run them in what I consider very demanding usage as it is driving tactile devices pushing very low frequencies (one is pushing a shaker and the other a jbl sub used as a Heze FootTR device) and both have been rock solid neven during my intense back to back to back demo scenes. Knock on wood :D
This is a review and detailed measurements of the Fosi Audio V3 Mono class D amplifier. It was sent to me by the company. The price with the power supply I tested is US $139.99.
I must say the concept of a "monoblock" amplifier in such a small size runs foul of any expectation a longtime audiophile would have! But monblock it is even though it is a very small block. Controls are on/off/trigger audio and selection of XLR vs RCA inputs -- just like the big boys! :) I am not showing the sides of the amp but there are very large holes with attractive orange color grid showing through. Nice. Back panel is again a bit of a shock to the system seeing XLR input:
The power supply as noted, is quite beefy with 48 volts at 5 amps on tap (240 watts). The amplifier is stated to have PFFB implementation which for a class D amplifier means it should have no load dependency together with lower distortion. Let's see if we get these with our measurements.
Fosi Audio V3 Mono Amplifier Measurements
Let's start with XLR input:
Wow, I did not expect this class of amplifier to break through the 100 dB SINAD barrier but the V3 Mono does exactly that, placing it in our prestigious category of "excellent:
RCA input costs you some performance but I was relieved to not see any mains interference:
Distortion is still at provably inaudible -115 dB. I like that the gain is nominal 25 which is my new recommendation for amplifiers.
Noise performance is excellent and at full power, darn near approaches sate of the art:
Now the all important frequency response and load dependency test:
There is essentially no impact up to 20 kHz between the 4 and 8 ohm indicating very low output impedance, albeit with a bit of peaking. Compare that to non-PFFB amps such as Fosi Audio V3 stereo Amp:
Above we have 2 dB differential at 20 kHz.
Distortion is very low and only increases with frequency:
Let's see how much power we can get out of this little box:
Efficiency must be quite high as we get essentially the power we put in (the power supply likely has some headroom).
There is decent amount of power even with 8 ohm and with very low noise:
As note though, distortion does rise at higher frequencies:
Fortunately it is good where our hearing is very sensitive (below 5 kHz).
I also threw my suite of my punishing reactive loads at it:
Translating into watts:
Amazing that this little amplifier can handle even 2 ohm load! Note that these are short term power ratings.
There may be a bit of power on noise:
All I can say is wow! It is incredible how far these small amplifiers have come. It is the result of a manufacturer listening to our needs, implementing features such as balanced and trigger inputs, and proper feedback mechanism to essentially eliminate load dependency. I can't imagine asking for more from Fosi when it comes to such an amplifier. Everything is as good as you could possibly want.
It is my pleasure to recommend Fosi Audio V3 Mono amplifier.
WOW! yeah gonna beg borrow s...l 2 get me a pair soon. Thanks Amir. U R the best gift to us 72 y.o. audiophile of yore.
I ended up returning all 4 of my V3 monos. I bought 2x 2 sets with 10 amp power supply. 1 of 4 amps died fairly quickly, although I was torture testing them beyond what any normal person would do (although the one that died was on lightest duty @ around 90 W into 8 Ohm continuous for many hours). Their form factor is too small for the power they CAN put out. I drove them pretty hard, and they performed. But without extra cooling, they couldn't cut it.
Two of them handled 2 Ohm each on either side of a dual voice coil monster sub. In the end it did feel underpowered, but they were impressive nonetheless.
Replaced with real 2.4 kW Class D sub amp, and Topping PA7 Plus for highs (since they available locally and much less cables and power supplies for basically the same performance - although closing in on dbl the price). Great if you want a "desktop" monoblock system, or even a simple monoblock floor standing setup on a budget.
But I need more reliable, and certainly more power in low Ohm bass. Worth the experiment, very capable little units for the price.
Hello everyone!
I apologize for my English right away.
Nice measurements, but one of my V3 monos burned out on the first day. I know there are more cases like that.
V3 mono has poor heat dissipation. It is a poorly designed device and probably not carefully assembled. Fast mass production. Too small a safety margin. It has too small a radiator. With such a small space inside, it boils inside.
First of all, there should be thermal protection. The amplifier should turn off and work after cooling down. This morning I connected it cold to test. One works and the other is dead, only the indicator light is on and the relay clicked.
In my case, the cooler one failed. So it probably gave off less heat. Underneath there is a radiator connected to the housing with thermal paste, like in a computer processor. The housing should give off heat because it is also a radiator. Apparently there was too little paste or poor adhesion.
- I would disassemble it as if I were replacing opamps. I would buy the best processor paste possible, remove the old one and carefully install the new one.
- Second thing, the feet are too low. Air should flow underneath. I would install some small metal spikes to make some air space. Alternatively, I would place the amplifier on a nice black radiator as a base, gluing it to the bottom with a thermal pad.
- Or indeed, put some slow-running, quiet fan under the amplifier. Of course, there has to be air flow. The manufacturer knows about overheating, because they sell fans for $37. They should be included with every V3 mono.
But it will all ruin the design, which is quite nice in a way. That's all you can do I'm calling the seller right now and saying goodbye to Fosi.
My rating - a headless panther.
to add to this when i opened my two and changed Opamps, i noticed very little thermal paste on one and a lot more on the second amp but still a small blob in the center of the heatsink. wish I took photos but it was a off white oily cheap looking paste too, I replaced it with MX-6 which happens to be a thicker paste on the chip and on the heatsink. but before putting it back in, I spread it across the whole block thick and evenly so i can get the most out of the plate moving heat with a fan nearby. another thing i would say is the orange panels they use as dust filters don't really allow much air to pass through if you slide those out while the amp is open you can see that the bar holding the amp together inside from front to back blocks airflow too.
so i do agree there is some short comings to the design that had to be done to make such a cheap amp and better QC should be happening for these units that are broken recently.
I have the two monos on top of each other (the DAC on top). Yesterday, after the monos had to work for several hours while watching TV at normal room volume, both of them suddenly produced an unpleasant noise in parallel, in addition to the normal sound. First quietly and then gradually increasing to a certain level.
I touched the amplifiers and both were very warm, despite the low volume. Turning it off and on didn't help. The noise came back immediately, a little quieter than before but rose back to the previous level.
The noise is independent of the volume set on the DAC.
I use the RCA inputs at 25 dB gain and RCA outputs on the DAC.
Can someone help me with this problem. Has anyone else had this too?
I don't know much about amplifier electronics, but I previously thought that one advantage of the class D design was, among other things, its high efficiency.
Now I'm wondering why this heat production occurs even though only a minimum of the maximum possible performance is required.
If they both started producing the same noise at the same time, that suggests the problem is upstream - eg the DAC or further upstream - eg the TV losing sync with the DAC.
It is vanishingly unlikely they would both fail at exactly the same time with exactly the same fault.
Try a different source to feed the DAC or a different device into the amps.
this is why I didnt grab them at first when they came out. guess my next amp will be a DIY kit.
Better yet, DIY this bad boy amp (fosi-audio-v3-mono, no toggle switches, just the complete assembled board) and I will definitely get 'two' and put a very good ventilation and heatsink in one chassis!
How have you got this configured? Is the fan running off a media player?
Yes, basically running of the media player. In my case the LCD panel on the left of the picture runs some VU Meter software on a Raspberry Pi. The fan is connected to the PI's GPIO pins to spin them up when only when audio is playing.
