ocinn
Amazing, however still handily beat by the 3E audio boards as measured.
Wonder what the 3E guys know that fosi does not yet.
I think probably difference in gain, and the provision of DIP8 makes the difference - or substantially explains it.Amazing, however still handily beat by the 3E audio boards as measured.
In a monoblock amp? How would you manage channel imbalance?I would like a gain control like e.g. the Topping P5 has. Using them in a active system, a volume knob is useful. Otherwise, awsome.
Historically it was not uncommon to include gain control on power amps, often pr. channel, like my old Kenwood L-1000M. This is useful for gain staging and when running them as part of active system. Agreed not all has, but the Topping PA3/5/7 does, which is a main competitor. Also when used with a DAC without volume control, a knob on the front here would expand it's usefulness.
Essentially the same gain (0.64db more on the Fosi).I think probably difference in gain, and the provision of DIP8 makes the difference - or substantially explains it.
Using two. Several ways to handle balance.In a monoblock amp? How would you manage channel imbalance?
Yes ... in ones like Fosi's ... or bigger with power supplies ... or if someone like audiophonics would offer the pre-drilled kit at a decent price...Essentially the same gain (0.64db more on the Fosi).
Must be something else. 3E has much better load dependency, multitone, two tone multi, significantly better power:THD-N behavior, much better freqower plot, and better reactive load performance. If only they offered them in a pre-built plug-n-play enclosure.
Likely people angered by buying something far more expensive that offers nothing over this, or in many cases is put to shame by it. The kind of cultist's who will defend a purchase with more vigor than their own kids. Lol, we need a reboot of the Taken franchise where Liam Neeson play's an audiophile.
You've been around long enough to know that there are always a few - just like those voting 'great' for the expensive things that measure badly.
Looks like Fosi changed the page, just one button to subscribe now. https://fosiaudio.com/pages/monoblock-power-amplifier-v3-monoSomething to do with the browser flavour - Chrome fails to display the Fosi home page and other pages correctly (at least on this laptop!); Firefox + its derivatives seem to show all pages correctly but still missing the early bird discount link !!
However, using Firefox on an Android tablet both the "early bird discount form" and the "support us on Kickstarter (Pending)" tabs were showing. Not confident that the discount form was actually sent, or maybe sent several times.
Obviously a difference between mobile and PC web pages but please sort out these software bugs!!
No doubt there will be one or equivalent going forward, great leaps in quality seem to be what these companies do so well. In 10 years time, imagine, manafacturers are really going to have to kick it up a notch.
What amazes me is how a company like Fosi Audio actually listens to customer feedback and implements high quality parts that big companies charging big money wouldn't bother with. I was skeptical to a degree, but after seeing this review and heading to their website I was actually quite impressed.
But it seems that Fosi is still developing the V3 Mono, see #14 of this thread:Essentially the same gain (0.64db more on the Fosi).
Yeah, this is definitely something that companies like Fosi and WIIM excell at, there's not many companies in this world that are so customer focussed. Let's just hope as they grow they maintain this and don't fall into the standard set by others.Yes, few companies want to talk to their customers nowadays, I bought lots of products from many brands, but I have never talked to them so close.
I believe that’s how it works and although it is totally irrelevant for the performance aspects, it can be important functionally: my experience with these auto-power is that they tend to turn the amp off during quiet music passages, which is (very!) irritating… It’s a fine balance between setting the right thresholds (what is “no (analog) signal”? Is the “on” threshold the same as the “off” threshold?) and right timers (do you power “on” immediately? How many ms is “immediately”? How long do you wait with “no signal” before powering “off”: 1, 5, 10mn ?)Edit: Just noticed the auto option on the power on/off switch on the front panel. Does this auto detect an incoming signal and switch on and switch off again if no signal is present?
This is a review and detailed measurements of the Fosi Audio V3 Mono class D amplifier. It was sent to me by the company. The price with the power supply I tested is US $139.99.
I must say the concept of a "monoblock" amplifier in such a small size runs foul of any expectation a longtime audiophile would have! But monblock it is even though it is a very small block. Controls are on/off/trigger audio and selection of XLR vs RCA inputs -- just like the big boys!I am not showing the sides of the amp but there are very large holes with attractive orange color grid showing through. Nice. Back panel is again a bit of a shock to the system seeing XLR input:
The power supply as noted, is quite beefy with 48 volts at 5 amps on tap (240 watts). The amplifier is stated to have PFFB implementation which for a class D amplifier means it should have no load dependency together with lower distortion. Let's see if we get these with our measurements.
Fosi Audio V3 Mono Amplifier Measurements
Let's start with XLR input:
Wow, I did not expect this class of amplifier to break through the 100 dB SINAD barrier but the V3 Mono does exactly that, placing it in our prestigious category of "excellent:
RCA input costs you some performance but I was relieved to not see any mains interference:
Distortion is still at provably inaudible -115 dB. I like that the gain is nominal 25 which is my new recommendation for amplifiers.
Noise performance is excellent and at full power, darn near approaches sate of the art:
Now the all important frequency response and load dependency test:
There is essentially no impact up to 20 kHz between the 4 and 8 ohm indicating very low output impedance, albeit with a bit of peaking. Compare that to non-PFFB amps such as Fosi Audio V3 stereo Amp:
Above we have 2 dB differential at 20 kHz.
Distortion is very low and only increases with frequency:
Let's see how much power we can get out of this little box:
Efficiency must be quite high as we get essentially the power we put in (the power supply likely has some headroom).
There is decent amount of power even with 8 ohm and with very low noise:
As note though, distortion does rise at higher frequencies:
Fortunately it is good where our hearing is very sensitive (below 5 kHz).
I also threw my suite of my punishing reactive loads at it:
Translating into watts:
Amazing that this little amplifier can handle even 2 ohm load! Note that these are short term power ratings.
There may be a bit of power on noise:
All I can say is wow! It is incredible how far these small amplifiers have come. It is the result of a manufacturer listening to our needs, implementing features such as balanced and trigger inputs, and proper feedback mechanism to essentially eliminate load dependency. I can't imagine asking for more from Fosi when it comes to such an amplifier. Everything is as good as you could possibly want.
It is my pleasure to recommend Fosi Audio V3 Mono amplifier.
Do people usually use monoblocks with a pre-amps of some sort where they actually adjust volume?
I imagine people usually set both monoblock amps at top volume, and then actually adjust the volume via a remote control streamer/pre-amp? Or how do you make sure volume is equalized on both channels?
Thanks, sorry for the dumb question.
