Inertiaman
- Joined
- Sep 25, 2023
- Messages
- 289
- Likes
- 666
Good point, I hadn't reviewed the photos of the enclosure. Having now done so, I still see simple opportunities for improvement. Maximizing airflow on all surfaces of the chassis (both interior and exterior) would benefit heat dissipation. So offsetting the holes on the side panels (left side high, right side low, for example) would improve the passive convective airflow through the unit. I can't quantify the scale of the benefit, but certainly it would improve, no?There is (and can be) almost no vertical air flow in this design. The entire area is blocked by the PCB - where are you expecting air entering the bottom of the case to go?. The thermal design relies almost entirely on conducting heat to the chassis. There will be some small trickle of air out of the side vents, fed though the small gap between the edges of the PCB and the housing.
Frankly I wonder if, given the orientation of the TPA3255/heatsink/chassis, would the unit run cooler if placed upside down??
