saberger0357
- Joined
- Oct 25, 2018
- Messages
- 251
- Likes
- 227
And is opening the up the only way to know for sure if they're reversed or not?Definitely as of last week
You can also use a test track, and hear the results.And is opening the up the only way to know for sure if they're reversed or not?
I just posted in another thread, I have terrible experience with @Fosi Audio support too. I can only advise anyone not ordering from them directly, support wont help, dont honor their own return policies and act against european laws. Besides my support guy is insulting my will to return item. I think i never had such a terrible experience with support.Everybody talk about good customer experience of @Fosi Audio , mine is one of the worst i had. After almost 3 months , i have no monos( stuck in Spanish customs) , money is gone, i was a pledger, and @Fosi Audio doesn´t provide a solution. What a scam.
That's my experience also. Order from Amazon, and return it if you're not happy. No questions asked.Dont order from Fosi directly!
Sorry for the bad experience. Let me help you resolve it.Everybody talk about good customer experience of @Fosi Audio , mine is one of the worst i had. After almost 3 months , i have no monos( stuck in Spanish customs) , money is gone, i was a pledger, and @Fosi Audio doesn´t provide a solution. What a scam.
The ones I received last week from amazon UK were the correct polarity.So is Amazon still shipping the reverse polarity versions?
Afraid I can't recall, I don't have the amps as I returned themHow many QC stickers are at the bottom ?
Different Amazon.xx may have old and new deliveries, which could be of different status.
Are there any good reasons to put a DAC in between a Wiim Ultra and a pair of Fosi V3 monoblocks? I have an extra DL200, for instance.
None at all with one minor exception:Are there any good reasons to put a DAC in between a Wiim Ultra and a pair of Fosi V3 monoblocks? I have an extra DL200, for instance.
Yes, so you can use XLR. (which got way lower thd on v3 mono)Are there any good reasons to put a DAC in between a Wiim Ultra and a pair of Fosi V3 monoblocks? I have an extra DL200, for instance.
Again - only beneficial if experiencing audible ground noise without the XLR.Yes, so you can use XLR. (which got way lower thd on v3 mono)
https://archimago.blogspot.com/2024/08/part-ii-fosi-audio-v3-mono-amp-class-d.htmlAre there any good reasons to put a DAC in between a Wiim Ultra and a pair of Fosi V3 monoblocks? I have an extra DL200, for instance.
More like 13-14dB at the same voltage and different,highest gain (Arch also measures XLR with 2V output,so it's easy to compare)Just the standard and expected 6dB resulting from the lower voltage/higher gain. Still inaudible.
no and you could also adjust sub timing within the wiim app btwIf I were to do that (add a DAC like the DL100) for the dB gain or hum, with the Wiim DAC managing the subwoofer, do I potentially introduce 'timing' issues?
Try it and see ...If I were to do that (add a DAC like the DL100) for the dB gain or hum, with the Wiim DAC managing the subwoofer, do I potentially introduce 'timing' issues?
