By my observations it cools down a bit in "Auto"-mode. It does not shut down "completely"...srry for my stupid question...but I want to know if after the 10 mins. without signal it remains hot at around 43° or shuts down completely?
Nice. I wish they had internal power supply, not that bulky box outside, considering you need two. Oh yes. Or one 10 A. Btw can l change the op amps inside ? What s the best solution?This is a review and detailed measurements of the Fosi Audio V3 Mono class D amplifier. It was sent to me by the company. The price with the power supply I tested is US $139.99.
I must say the concept of a "monoblock" amplifier in such a small size runs foul of any expectation a longtime audiophile would have! But monblock it is even though it is a very small block. Controls are on/off/trigger audio and selection of XLR vs RCA inputs -- just like the big boys!I am not showing the sides of the amp but there are very large holes with attractive orange color grid showing through. Nice. Back panel is again a bit of a shock to the system seeing XLR input:
The power supply as noted, is quite beefy with 48 volts at 5 amps on tap (240 watts). The amplifier is stated to have PFFB implementation which for a class D amplifier means it should have no load dependency together with lower distortion. Let's see if we get these with our measurements.
Fosi Audio V3 Mono Amplifier Measurements
Let's start with XLR input:
Wow, I did not expect this class of amplifier to break through the 100 dB SINAD barrier but the V3 Mono does exactly that, placing it in our prestigious category of "excellent:
RCA input costs you some performance but I was relieved to not see any mains interference:
Distortion is still at provably inaudible -115 dB. I like that the gain is nominal 25 which is my new recommendation for amplifiers.
Noise performance is excellent and at full power, darn near approaches sate of the art:
Now the all important frequency response and load dependency test:
There is essentially no impact up to 20 kHz between the 4 and 8 ohm indicating very low output impedance, albeit with a bit of peaking. Compare that to non-PFFB amps such as Fosi Audio V3 stereo Amp:
Above we have 2 dB differential at 20 kHz.
Distortion is very low and only increases with frequency:
Let's see how much power we can get out of this little box:
Efficiency must be quite high as we get essentially the power we put in (the power supply likely has some headroom).
There is decent amount of power even with 8 ohm and with very low noise:
As note though, distortion does rise at higher frequencies:
Fortunately it is good where our hearing is very sensitive (below 5 kHz).
I also threw my suite of my punishing reactive loads at it:
Translating into watts:
Amazing that this little amplifier can handle even 2 ohm load! Note that these are short term power ratings.
There may be a bit of power on noise:
All I can say is wow! It is incredible how far these small amplifiers have come. It is the result of a manufacturer listening to our needs, implementing features such as balanced and trigger inputs, and proper feedback mechanism to essentially eliminate load dependency. I can't imagine asking for more from Fosi when it comes to such an amplifier. Everything is as good as you could possibly want.
It is my pleasure to recommend Fosi Audio V3 Mono amplifier.
What's worth saying is how gain reflects in it's measurements,specially with RCA input and how a totally decent 91.4dB SINAD at 1kHz/1W goes down to either 79dB for 25dB gain or 77dB SINAD at 1kHz/1W for 31dB gain.This is a great review (I think someone posted the part 1 here or on the user impressions thread)
Part II: Fosi Audio V3 Mono Amp; Class D + PFFB, TI TPA3255 - Retail box with single 48V/10A power supply and filter. [Power, Distortion, and Subjective Impressions.] And on rejoicing over "Solved Problems" in audio.
A blog for audiophiles about more objective topics. Measurements of audio gear. Reasonable, realistic, no snakeoil assessment of sound, and equipment.archimago.blogspot.com
"The Fosi V3 Mono sounds well balanced and "rich". Some people claim that Class D can sound excessively "thin". Well, maybe years ago this could have been the case but not with modern Class D amplifiers capable of hi-fi performance (low noise, full frequency response, low distortion, excellent transient response); they're just neutral-sounding these days".
Well put (you get down to this after all the measurements). Could not have put it any better.
After seeing the soldering my two Fosi Audio V3 Mono's are going back to Amazon UK for a refund.
And did you reverse the test also?Sorry to have made many friends confused. We can confirm the phase is the same for both RCA and XLR input based on the measurement using an AP analyzer.
Our engineer connected two V3 Monos, one with RCA input and the other with XLR input. We can find that the phases are the same based on the AP test result.
I'm just being objective.@JBL321GO
Never mind, aren't You exaggerating a bit ???
Funny, I don’t see it that way. I guess it met and maybe exceeded my expectations. I always planned to use balanced inputs and I did what I thought was the obvious thing and chose two 5A power supplies. It is silent, it has heaps of juice, the auto functions without any issue and I feel like it does justice to my equally impressive and affordable SMSL DAC.This whole V3 Mono story is a true debacle.
First, noise issues, then reversed polarities. What next?
Are You ???I'm just being objective.
It's because his measurements are at 1W and not 5W as Amir's plus whatever sample-to-sample variation may be and gain penalty.Interesting that Archimago measures single-tone distortion when using RCA input as 13dB worse (80dB vs 93 dB) than Amir's measurement.
I wonder if it's because he is using the 10A PSU? He picks up 10-15dB of 60Hz mains hum whereas Amir did not.
Plus, Amir puts a lot of effort into the cleanliness of the setup to avoid introducing mains hum.It's because his measurements are at 1W and not 5W as Amir's plus whatever sample-to-sample variation may be and gain penalty.
You can see the penalty in XLR input here:
At 5W is 100dB SINAD and at 1W is near 95dB SINAD.
That's true but in this case (Arch's RCA input) noise competes with distortion at equal amounts.Plus, Amir puts a lot of effort into the cleanliness of the setup to avoid introducing mains hum.
Golden sample? I dont think we can critizize archimagos results, He knows what hes doing.That's true but in this case (Arch's RCA input) noise competes with distortion at equal amounts.
It wouldn't have a better result even if one of two was way lower.
No,no golden sample as Arch's XLR results are perfectly in check with Amir's.Golden sample? I dont think we can critizize archimagos results, He knows what hes doing.
So is Amazon still shipping the reverse polarity versions?
