The klipsch heresies with half a volume knob at 32v are already moving strongly. You have half a knob left. I ideally recommend using dacs with 2 vrms output as a minimum and maximum. This way you get all the juice out of it without distortion. I have a 3 vrms one and at half knob it starts with distortion, so I changed it.depends on your speakers
if you own the famous klipsh heresys then 34w is fine
but all this being equal i would take the 48v psu given the avg. speaker is probably not 99db SPL
Sound will be the same if you stay within the volume limit, and don't drive the amp to clipping.My mean is, which psu will make sound quality better. Thank u.
My LS50's sensitivity is 85 dB and I forget to exit DL, that probably would make a big difference, like 10 dB or moreI got 103 db spl with the 32v 5a, 88db sensitivity speakers. I compared it with the topaz sr10 v2 and the fosi tb10d, and the v3 sounds clearer, the voices are clearer. Dac 1.5 vrms.
If you go back and read the review that started this thread, you'll see that(as indicated in the post above) at 8 ohms the V3 is capable of 89 watts with the 48v brick(141 watts @ 4 ohms). You should have no difficulty driving most speakers, including the Yamaha's, which are fairly efficient at 90 dB @ 1W. The power handling capability numbers are irrelevant for the most part.Sorry didn't have time to read the whole thread.
I was one of the kickstarter backers of this thing and just now trying it out (48v version).
I have it running my Auratones 5C, specs say they have Power handling: 25W RMS/50W Peak.
It does ok. I like it. I'm not sure it really has 300Wx2 though, lol. I think it surely has at least 25Wx2 to drive Auratones, but my volume dial is pretty much at max and they're not too loud...
I was hoping to get another little Fosi amp for my NS10Studios, but those have power needs: Capacity: 60 watts(PROGRAM), 120 watts(MAX) Nominal Impedance: 8 ohms
Will it be comfortably sufficient for the NS10s (somehow I doubt it)? They say if the amp too weak tweeters will eventually fail, if too strong it will just easily blow them up at slight accident.
Sorry, I find all this technical stuff a bit too confusing. If V3 is too weak what other model would work? I don't want a big box on the desk, trying to stay minimalistic.
my reading is that the V3 is a amp with a lot of power able to push just about every common speaker to spl that isnt healthy or sustainable in modern polite society
89w at 8 ohm, 140w at 4 ohms.., yeah this thing is a power house
i think people are unduly caught up with V3 power because of a few people here there and everywhere who dont know what they are doing... and these people are doing reviews, further spreading their lack of knowledge
if you have a speaker than falls outside of what is a 'normal' speaker, eg. electrostats, then you should know what your bought
Fosi gave a reason why they advertise "300w" and if it does 140w x 2 at 4 ohms then really this isnt false advertisement?
Amir is known to test hard and its not out of the ordinary to expect that in some tests, it could do 150w x 2 @ 4 ohms?
| Specifications | Details |
| Model | V3 |
| Chip Set | TI TPA3255 |
| Output Power | 300Wx2 @4Ω |
| Terminating Impedance | 2-8Ω |
| Input Mode | RCA |
| Output Mode | Speaker Output + Pre-out |
| Frequency Range | 20Hz-20kHz(±0.1dB) |
| SINAD | 88dB |
| THD | 0.003% |
| SNR | ≥110dB |
| Control Knob | Built-in Logarithmic Taper A pot |
| Device Dimension | 6.5x4.1x1.4 inches |
| DC Input Range | 24-48V |
| Power Supply | 32V/5A, 48V/5A |
300 watts is the unrealistic measurements by the chip maker at 4 ohms with a 48v/10a power supply at higher distortion levels.
Texas Instruments encourages their manufacturer's to advertise maximum specs as needed. See the linked Texas Instrument White Paper advising manufacturers how to advertise their chip power ratings that I posted here.300 watts is the unrealistic measurements by the chip maker at 4 ohms with a 48v/10a power supply at higher distortion levels.
I agree that, at least for those of us who scrutinize ASR and other similar audio forums, being as transparent as possible would be a benefit for Fosi. But realistically, they are not the first, only company to "devise creative ways to use power ratings for advertisements"(I love that). Audio companies have been doing this forever. It's always been up to the consumer to try to sort through the hype and if the product their contemplating buying will suit their needs. Having resources like ASR is great, and I'm guessing that a fair amount of folks who buy Fosi products at least know about this site, or take the numbers with a grain of salt, or both.Texas Instruments encourages their manufacturer's to advertise maximum specs as needed. See the linked Texas Instrument White Paper advising manufacturers how to advertise their chip power ratings that I posted here.
Key Quote from the 4th page:
The need for attractive marketing strategies requires TI customers to devise creative ways to use power rating for advertisements.
This paper assists TI customers in determining the suitable power rating to be used in the advertisement of their products. TI supports customers internationally and understands that each region of the world requires different marketing strategies. While the power rating for the US market is dictated by the FTC, other countries may not be restricted to such requirements. In those cases, TI customers are open to choose the acceptable power rating for advertisement. As mentioned in the introduction, PMPO generally is not well-defined and accepted as an audio performance measurement. It is used mostly for advertisements.
Note this was written before 2005, since then the FTC no longer enforces power rating restrictions in the U.S.
I do not think it is smart for Fosi to advertise these max chip power ratings on the V3, even if TI says it is OK. The V3 is Fosi's first product aimed at tech savvy audiophiles who read and understand specs. if they are smart future advertising of the V3 and other products aimed at this market will use their actual measured specs for the product, not the TI chip spec ratings.
