i doubt it. but we can't tell from the measurement you posted.so in my environment the v3 would not cause problems?
It is quite likely to get hotter with the higher voltage.Can it be, that the Fosi V3 gets hotter inside with the 48 Volt 5 ampere Power supply, than with the 32 Volt power supply, even if you just use 0.1 Watt (which is realistic with normal music listening) or there is no music playing at all?
I doubt it. With my 48 Volt 5 Ampere power supply, the Fosi stays pretty cool (perhaps 37 degree Celsius).
Did anyone made a propper measurement?
How does the frequency response of your speakers tell us anything about the transitory boom you are hearing at power up?this is the frequency response with the Fosi v3 at maximum and the Denon at 9.30 o'clock there are no increases in the high frequencies
As I said above - you can't see problems from an amp by measuring through speakers with a mic in room. The speaker/room interaction dominates the measurement results.I took the frequency response not for the boom, but to check the variation at high frequencies with my speakers. Are there always no problems?
I say, that in real listening in my environment there are no exaggerated highs, so the Fosi v3 is good for my listening or am I wrong?As I said above - you can't see problems from an amp by measuring through speakers with a mic in room. The speaker/room interaction dominates the measurement results.
If it sounds good to you, that is all you have to worry about.I say, that in real listening in my environment there are no exaggerated highs, so the Fosi v3 is good for my listening or am I wrong?
To the loudspeakers, the turn on and off pops are just signals, no different from the music you play. As long as the pop sound output is comfortably less than the max output SPL level of the speakers, everything should be just fine.sorry, but can the boom when turning on and off break the speakers or is it just a nuisance?
It sounds like the boom when the needle of a record player hits the recordTo the loudspeakers, the turn on and off pops are just signals, no different from the music you play. As long as the pop sound output is comfortably less than the max output SPL level of the speakers, everything should be just fine.
One thing I would like to confirm, however, is that the amp is not outputting DC during the pops, which can cause large excursions of the woofers that we can't hear. You can verify that by looking at the woofer diaphragms. If they don't move considerably during the on-off pops, then there is no DC problem.
you've got is sat direction on the vents of the device below. If that is switched on at the same time as the FOSI I'd not recommend it.View attachment 388626Can Fosi stay there or not?
You have the answer in this review - the very first post in this thread:Hi, will this Fosi V3 give a speaker "pop" when power Up and Down used on a Master/Slave power socket ?
The receiver will be the "Master" and the V3 will be the "Slave" and will be turned on and off by the power socket when the receiver powers up and down.
The power knob on the V3 will be aways ON.
Think using a Master/Slave power socket works the same as pulling the power cord to tun on and off, intade of using the power knob on the V3.
Maybe someone can check by pulling the the power cord of the extrenal powerblock if the speakers pop ?
No. It will be able to go louder but I don't think you are running at max output?Does the sound improve if I power it with 48V 5A GaN power supply?
is it better to set the volume of the Fosi v3 to 3 o'clock or to maximum?Is it normal that when I set the volume of the Fosi v3 to maximum I hear a lot of mid-highs, even if the volume of the Denon preamp is at minimum?
What I would do:is it better to set the volume of the Fosi v3 to 3 o'clock or to maximum?
