What?Kudos to Fosi Audio for going above and beyond and including a highly functional spilled coffee safety device on the V3.
Worth trying hair dryer heat up for 10-15 min.A follow up to my spilled coffee mishap. I just finished the reassembly after a good cleaning and it's a no go. The blue light comes on and I can hear a protection circuit click when the volume knob is close to being shut off but no music. Nothing looked out of the ordinary and I couldn't even find a coffee stain. I'm thinking no more than a half teaspoon found it's way to the board but sadly it was enough to ruin it..
Dried up residue might still be the problem. Before giving up I'd give it a bit of time to make sure all capacitors discharged, thoroughly wash/bath the amp in distilled water, leave it to dry in a warm airing cupboard or warm place for at least 48 hours then give it another try.Worth trying hair dryer heat up for 10-15 min.
I'm thinking this is my best option given the price.You can of course also user 'proper' cleaners but it's a cheap amp to replace![]()
628 global ratings on Amazon -> 94% ratings are 3,4,5 stars -> 2% are 2's & 4% are 1's -> guess I interpret the results different...The V3 is on sale again, so I checked Amazon to see what their user reviews look like. Wow. Lots of comments about unusably low volume, murky sound, 1 and 2 star reviews. Strange for something that measured so well in testing. What gives? Have Fosi been selling thousands of these, so the bad reviews are just the tiny number of defectives shipped out? Or is their QC not so hot?
I think these review articles are the result of ignorance of Chinese products and a lack of technical knowledge. The contents of the reviews are all things I already know and I have no problem with them. However, Fosi should change the expression "PREOUT". It confuses buyers.The V3 is on sale again, so I checked Amazon to see what their user reviews look like. Wow. Lots of comments about unusably low volume, murky sound, 1 and 2 star reviews. Strange for something that measured so well in testing. What gives? Have Fosi been selling thousands of these, so the bad reviews are just the tiny number of defectives shipped out? Or is their QC not so hot?
Many simply compare it against there old gear and then not finding those advertised power output becomes a concern for a common user.I think these review articles are the result of ignorance of Chinese products and a lack of technical knowledge. The contents of the reviews are all things I already know and I have no problem with them. However, Fosi should change the expression "PREOUT". It confuses buyers.
As for QC, there are many problems from the perspective of our society. However, these are products of a country whose social system is completely different from ours. Therefore, it is difficult to directly apply our common sense to them. You need to fully understand this before purchasing.
All volume controls use a logarithmic ('audio') taper. Even way back in the days of mono 78s, manufacturers knew that log taper pots were more intuitive to use, more adjustability at lower to medium volume, rather than sounding like the amp's playing nearly full blast with the vol ctrl turned less than half way up.Many of those complaining about "low volume" probably need to be pointed to the start of this thread... to understand that the volume pot is using a logarithmic scale. I have 4 x Fosi Audio V3 and all have been working flawlessly... knock on wood.
People also don't understand what 'gain' means. What is the gain (in decibels) of the V3? At what input signal voltage does the amp reach full power?
Good to hear your Fosi V3 amps are working well.
Hello,No!
Capacitors are glued to the PCB, probably you wouldn't have the same problem with rattling capacitor like @amirm with test example.
Thermal paste is for the metal part on the TPA3255 and the case. Not needed of course, but can be useful in better transfer of heat to the case.
A few more parts and as simple as is proposed from TI.
The biggest problem is a gain of (only) 19 dB with PFFB (like with Topping PA5). It will be a lot of complains from customers and @Fosi Audio wouldn't like that, I presume.
@Fosi Audio, you announced a new model after V3 with double XLR inputs, so when we can expect that product?
I hope you will ditch that 32V/5A PSU and you will start with a 36V/6A as a basic PSU.![]()
You shouldn't. You are very unlikey to be able to make such a mod work.Hello,
What should I do to replace input opamps by an unbalanced input tube buffer in the Fosi V3? How to find exactly board points to replace opamps outputs by tubes outputs? What is the V3 input impedance?
All help will be much appreciated!
Thank you guys!
