The USB port can easily be retrofitted using a DDC, such as the PO100 or U2PRO, for €35-60.
True galvanic isolation for USB is then included free of charge.
So that I (we) don't have to have multiple hardware, to route processed-analog audio from products like a DAP, a PC, or any other digital audio source.Thank you for your interest in Fosi Audio’s streaming products,why you want a USB? ...
...you use the USB,to the host or link a DAC?
Thank you for your interest in Fosi Audio’s streaming products.I totally can.
Bluetooth on this is surely an afterthought, home theater connectivity and network streaming are the main focus.
If Fosi are too cheap to include a USB bridge in this, then they're totally cheap enough to use a slightly older Bluetooth receiver for half the price.
thank you !Doesn't have it. People basically screaming for this in the Fosi community forum. Fosi is saying that S3 won't have USB I/O, but later models like the S3 Lite (more geared towards people planning to use an external DAC) and whatever the higher-spec model will be will also.
thank you !It's pretty badly missing Qobuz completely at the moment, although they're saying that Qobuz Connect is in the works.
Thank you for your interest in Fosi Audio’s streaming products.Finally a new streamer that makes sense!
Love the XLR output, the connect functions for Tidal ans Spotify, also Airplay and HDMI ARC.
Only thing I'm missing for myself is a additional loudness function, then it could really replace as simple solution my RME Adi-2 + Streamer.
Our goal with this product was to provide Hi‑Fi enthusiasts with a streaming DAC that delivers exceptional sound quality. That’s why we spent so much time tuning the audio performance and included professional-grade audio interfaces.
Regarding your suggestion about adding a volume gain feature—could you share why you’d like to have this function?
Full agreement. It's a bit odd that something named Ultra doesn't reach up to this.A device like your streamer should also be able to function as a dac for other devices. It would be perfect for a desktop setup if it had all the inputs: USB C for input from a PC (top requirement). HDMI for input from a TV for watching movies with a Fire TV stick (second requirement). Coax and Optical for other devices like a CD player or digital radio.
It should also be able to function as a headphone amp to eliminate the need for another box.
My dream device would be something like the Wiim Amp Ultra if it had all the needed inputs and included a headphone amp. A one box solution that covers everything.
Thank you for supporting Fosi Audio’s streaming solutions.Wiim seem to be great at updating their software, can we expect Fosi to do it as well?
I’d suggest connecting the S3 directly to the ZA3, assuming the ZA3 still has an available audio input.Hi, I'm new in this forum.
I have 2 ZA3 Monoblock and a pair of ELAC Debut 2.0. I have my turntable connected to Izi Zen Air phono amp, and that goes directly to the 2 ZA3s.
If I get this new S3 do I need to get rid of the IZI Zen Air and hook up the Turntable directly to this DAC?
What would you recommend it should by my next upgrade?
Turntable ATLP60 with needle from LPgear.
IZI Zen Air
2 ZA3 Monoblocks
ELAC Debut 2.0
I'm looking for 2 things, first better audio fidelity. And second the option to be able to play from more sources right know I only use my system for the turntable.
Also, if I do get this one. How can I connect this so it triggers both Za3 monos, and control volume?
Thank you for your interest in Fosi Audio’s streaming products. We’ll continue to optimize our products and the overall user experience.Rick Ruiz YouTube channel just posted a 1st look with a teardown. the S3 uses StreamUnlimited technology found in, I am told, some high end streamers from ArCam and midrange JBLs (like the Authentics series).
1st indications are it is GoogleCast 2 and Airplay 2 compatible. Ruiz says some StreamUnilmited skus include DIRAC. I love my WiiM Ultra and will not run out an buy an S3, but it is great that technology competitors to LinkPlay are stepping in. WiiM did not have room EQ at 1st either, and SteamUnlimited is a serious platform. I am pleased there will be new choices.
I would not use Bluetooth and do not see the limited codec support as a disadvantage.in what scenarios do you typically use Bluetooth on a streaming product?
Thank you for your interest in Fosi Audio’s streaming products.Ditto; rear of plastic/resin enclosure:
Exactly.. it all passes from a dbx DSP with an AutoEq function ..I don't know what Fosi will use ..but I don't think it's top level ..Dirac type.
Thank you for your interest in Fosi Audio’s streaming products.My thoughts exactly.
In my humble opinion 5 bands is not enough and here it really seems even the Q-value cannot be chosen which makes it basically just a graphical EQ with user interface based on sliders and (presumably) user-defined numerical values (ctr freq, I'd hope at least that would be freely selectable).
PS. to add - I've found the Wiim Mini a great purchase!
Thank you for your interest in Fosi Audio’s products.Even then, the Fosi has no screen, Phono in, Coax out, nor support for surround support. For the same price.
Sory for question but would like to know before buying; does Spotify connect support Lossless playing on Fosi S3?Thank you for your interest in Fosi Audio’s products.
We’re currently developing a model with a display and these interfaces, and if everything goes smoothly, it should be released later this year.
Thanks again for your support!
Here's a GEC mode...Thank you for your interest in Fosi Audio’s streaming products.
We’re continuously improving our products and app.
Below is the EQ interface we’re currently optimizing—we’re also expanding the EQ from 5 bands to 10 bands.
These updates are expected to be released in May.
I would hazard a guess and say this may even supersede the Wiim Pro Plus especially if you use XLR.Just found this...
Fosi S3 Music Streamer / DAC / Balanced Preamplifier
Buy Fosi S3 Music Streamer / DAC / Preamplifier in India with Free Shipping, GST Invoice, EMI Option and Official Warranty from The Audio Co.theaudio.co
If the price is as listed on the link, I don't know if anybody will pull the trigger on s3.
I am expecting it to compete with Wiim Pro+ but Fosi aim it at Ultra price wise.
