- Joined
- Aug 27, 2025
- Messages
- 73
- Likes
- 122
hello,is a Incremental Rotary Encoder@yuting
Can you tell which digital volume controller is used in S3?
View attachment 528215View attachment 528216hello,every one ,s3 lite DVT test product has finish.
Specifically says, “USB Out,” not just USB.USB is great addition, is it only USB output or USB host (to plat media disk as digital player) as well?
Nice lite version, probably at an interesting price point.
Can't imagine much for a "ultra" version though. Maybe USB out, and a touchscreen.
thinks ,this USB is only USB outputUSB is great addition, is it only USB output or USB host (to plat media disk as digital player) as well?
thanks It’s clear that you’re quite professional in the field of streaming, but I’d like to ask: where do you use your streaming products? Do you prefer streaming products that consolidate all features into a single solution, or would you rather have them tailored to specific scenarios—providing only the functionalities appropriate for each context, such as desktop or living room environments? After all, different scenarios may require different interfaces.I guess it will be focused more on the more premium appearance (metal casing), maybe a display and a more comprehensive pre-amp feature with discreet subwoofer filtering, maybe analog XLR inputs besides the RCA to serve as a more integrated, central hub.
If this has Airplay and Spotify connect then I am interested at least.View attachment 528215View attachment 528216hello,every one ,s3 lite DVT test product has finish.
thanks ,Why do you say the iPad provides more information than streaming devices? Besides controlling your music system, what else do you use the iPad for in this setup? Additionally, you mentioned having a large TV in your music system—what role does this large TV play in your music system? Thank you.The WIIM Ultra Amp has a USB A.
I use the Ultra Amp as the only component in a small room second system aside from the speakers. It is amazing how much is in that small box given its price.
I control it from a tablet which actually cost more than the WIIM. The tablet is great for ability to present far more information than one can read on a phone or any streamer screen. Plus I can put the tablet at my seat.
My main system which includes a large TV has a Nvidia Shield for streaming which is another small Swiss Army Knife.
of course have ,software the same with S3If this has Airplay and Spotify connect then I am interested at least.
Ok, thanks. So basically just the S3 without the dac and with all other components equal to the current S3?of course have ,software the same with S3
Hi @yuting, I received the S3 today and I'm really enjoying it so far. My device still has firmware version 0.0.200.0x7146fe2 and does not find any new version. Any clues why that's the case? TIAInternal and external testing has been completed, and the new version (v0.0.243.0xc4876da) has been released and deployed over-the-air (OTA). If no manual update is performed, devices powered on will automatically update to the latest version tomorrow. Thank you!
Spotify Lossless not good enough for you?Just connecting my iPad to my only dac gave far better resolution and a notable cleaner sound than the WiiM Pro too when connected over coaxial.
The only advantage any streamer might give me personally is not sound quality but ease. Using the iPad while sat in the armchair is a convenience that my aging carcass can easily welcome and afford. Controlling the S3 this way is my only use case advantage as the iPad is bit perfect when hardwired to the dac and sounds excellent.
