FOSI Audio Q6 Stereo DAC Review
Rate this budget DAC:
    Votes: 3 1.8%
    Votes: 22 13.3%
    Votes: 93 56.4%
    Votes: 47 28.5%
It's cheap. Is that really fair?
How quickly we forget that the Topping E30 II, good as it was, wasn't perfect either:
This is supposedly improved on the E30II Lite.
Even if it wasn't, I'll take auto standby, remote control, switchable Nyquist filter, nice sample rate+volume display over inaudibly better jitter and rollable Opamps any time.
For a dollar more, a separate power connection, similar to the Topping E30 II, allows true USB/Co-ax/Optical data input options.
The Q6 DAC was obviously designed for use with a laptop (or similar device) where the USB power and data inputs use the same connection. A separate 5V power input may improve the measurements, but this is only possible if Co-ax or Optical sources are available for data input. As Amir notes "It was a bit challenging to minimize USB induced ground noise". Fosi have lost at least one potential purchaser on this design decision. Perhaps including cable splitting USB and 5V power would be one solution.
On the other hand compliments to Fosi for using the XMOS X316 development-free board - saving development costs and using latest hardware.
They both use the AK4493 DAC chip and hence the same roll off in the filter.
But the WiiM Pro Plus with its AKM AK4493SEQ Chip has no such Problems - the Frequency response is perfectly flat!
I know, it’s not scientific, but I imagine to myself, that the WiiM Pro Plus alone sounds much better, than in combination with a SMSL D-6s with its ES 9039Q2 M Chip. Call it more musical, or more „organic“, even though the SMSL D-6s SINAD is 5 or 6 dB better than the SINAD of the included DAC of the WiiM Pro Plus.
An adjustable high-pass filter on the main outputs instead of a sky-high fixed low-pass filter on the sub output would have made this thing make a lot more sense. A digital volume control/preamp on top of that would have truly made this a complete package. Missed opportunities.
I'll Take E30II lite but if it was $45ca I'd buy now. I would like the simplicity in a particular system but not for the price
A budget DAC whose SINAD beats the Chord Dave,lol,lol,another lightening bolt of insight from the mighty Amir,made my day as I know and have tried to talk someone out of buying the Fraud Dave,(but I failed) I can send him this link,now,lol
The input switch knob is definitely overkill and eyesore. Most people never switch inputs during normal use, a small button to flip through inputs is fine as long as the selection persists across power cycling.
It is clearly designed to be ‘stacked’ below a Fosi v3 amp. There is no other reason for the switch design or the comically long shell.
It’s an ok product, the SW output is weird as others have noted. I went back to using my JDS Labs Atom+ for the most part.
I love big switches, my DAC/Headphone amp has a teeny tiny little switch that switched between pre-out/line-out/hp-out. If I'm not careful switching between pre-out and hp-out I feed my speakers a line level signal.
You are right! I had to look up what the footprint for a ufl connector looks like and it is spot on.
I just had an argument with Grok 3. It insisted Bluetooth was valid input source for Q6. It finally agrred with me. Chatgpt had no such delusion.
Just having an output to connect the subwoofer is useful. And since you will use the filter in the powered sub under 150hz, most likely 80hz, it will not interefere with practical use of the powered subwoofer.
that was not a very high bar
