Amplification before the volume control has the benefit that the self noise of the amplifier part also becomes lower when the volume is lowered.
Think the famous O2 design from NwAvGuy...
It also has downsides though namely distortion is higher and clipping can occur when a high gain + higher input voltage is present.
With the NE5532 self-noise with low to medium gain is not an issue though.
The downside is the high and variable output resistance which is in no way beneficial.
It isn't beneficial when the input impedance of the amp behind it is low due to volume setting dependent attenuation (voltage division) and the fact that a load capacitance can cause (volume setting dependent) high frequency roll-off when a higher cable/amp input capacitance is present.
This can easily happen with 'exotic' cables of more than a few meters and with amplifiers having a HF filter capacitor on the input (which is common).
When using a 100k pot at the input of the amp buffering is not needed and the input resistance will either be constant or just vary a little depending on the volume setting. The input resistance will vary less with 50k, 20k inputs and even with 10k input potmeters.
The downside of a high impedance is noise which is higher.
The upside is lower distortion but the self noise is constant. Using op-amps like the NE5532 the selfnoise is low enough not to become audible.
Another upside is low output resistance so no issues with any loads, can drive anything effortlessly. No volume control dependent issues.
For this reason all the high SINAD devices have low input and output resistances.
As far as pre-amps go the best design is a buffered input (maybe a few times gain), a low resistance volume control followed by a buffer (with or without some gain) and a low output resistance.
When it comes to benefits from a topology the amp first, high output resistance volpot after it then it would rank about lowest on the list.
Mind you ... it is really hard to make a (technically) poor performing pre-amp.
The voltages are low, the currents are low ... easy peasy.
So in most cases any of the 3 configurations will work fine. The P4 config, if it really is amplification followed by a high resistance volpot directly at the output, is the least desirable of the 3 because of the limited max gain and volume control setting dependent potentially audible HF roll-off>
It would still need to be confirmed by
@Carl-Fosi Audio that this is the case (but measurements suggests it is).
