Fosi Audio LC30 Speaker/Amp Switcher & Meter
Rate this speaker/amp switcher and meter:
    Votes: 29 19.1%
    Votes: 26 17.1%
    Votes: 64 42.1%
    Votes: 33 21.7%
I bought it used and for those cheap Chinese products there is no manual :facepalm:
There is a manual, the seller just didn't give it to you. So maybe be more cautious next time before you dismiss a whole product and origin category wholesale without cause.
I think I phrased that poorly. What I meant was that I don't have a manual for it.
By the way, it’s an Audioromy M828-A that I bought used for €220. I liked the look of the dual pentode, and I wanted to find out how it performs with my full-range speakers compared to my Hypex NCx500. The result was that the tube produces slightly less treble, and due to the higher distortion, the overall soundstage comes across as a bit more blurred.
But back to the resistor.
I double-checked this today and can also confirm it: When the amplifier isn't connected to the speaker via the switch, you can't measure that expected 370-ohm load.
I’d always wondered why the full-range driver's cone shifted inward by about a centimeter right after switching, only to slowly move back out again o_O
I’ve now connected a 470-ohm resistor across the tube amplifier's output terminals, and that unsightly excursion during switching is gone.
So, thanks for the tip :)
Just if you're interested. I added some electronics to the LC30 to change the meters to a calibrated operation.
Best DrCWO
A little update to my post about the LC30 not having any load protection for the unselected amplifier. Fosi Audio sent me an email about this confirming the gaps. If their hardware doesn't offer open load protection, fine, but they should say that clearly and not lead people to believe the device offers no load protection when it clearly doesn't. They have been called out on this for 2 years now and yet they still won't put warnings in the manual or any disclaimers in their misleading product information. They know better but they don't seem to care is the only conclusion I can draw from their refusal to acknowledge these gaps.
Thank you very much for taking the time to share such a detailed explanation of your experience with the LC30, including your testing procedures, measurements, and observations.
First and foremost, we sincerely apologize for the concerns and frustration this situation has caused you, particularly regarding the potential risk to your valuable tube amplifier.
We completely understand why this issue is important to you. Protecting your audio equipment is essential, and we truly appreciate the care and effort you have put into investigating this matter and bringing it to our attention.
We also recognize your concern regarding the information provided in our product description. We understand that clear explanations of the LC30's protection mechanisms and operating limitations are particularly important for customers using tube amplifiers.
After reviewing the technical details, we would like to provide the following clarification regarding the LC30's design and no-load protection functionality.
1. How does the LC30's no-load protection work?
The LC30's no-load protection mechanism only monitors the currently selected output channel.
If the speakers become disconnected from the selected channel, the protection mechanism will disconnect that channel's output to prevent the connected amplifier from operating under a no-load condition.
However, please note that this protection mechanism does not extend to the amplifier connected to the unselected channel.
2. Does the no-load protection only apply to the currently selected amplifier?
Yes, that is correct.
The no-load protection is designed to protect the amplifier connected to the currently selected channel that is actively driving the speakers.
It does not provide the same protection to an amplifier connected to an inactive channel.
We understand that this distinction may not have been sufficiently clear from the product information, and we sincerely apologize for any misunderstanding this may have caused.
3. Is it normal for the unselected amplifier channel to remain open-circuit?
Yes. This is part of the LC30's normal hardware design and does not indicate a malfunction.
The LC30 uses relays to switch between amplifier channels. When a channel is not selected, its relay contacts are disconnected, resulting in an open circuit.
This behavior is determined by the hardware switching mechanism.
Additionally, the behavior you observed when the LC30 is powered off, where Amp B is automatically connected to the speakers, is due to the relay's normally closed contact configuration.
This is a characteristic of the relay design and is not related to the no-load protection function.
4. Could this operating condition pose a risk to tube amplifiers?
Yes, there is a potential risk, and we would like to emphasize this point for your safety and the protection of your equipment.
Unlike most solid-state or Class D amplifiers, which can generally tolerate an open-circuit output, traditional tube amplifiers with output transformers typically require a suitable speaker load during operation.
If a tube amplifier is powered on while its output is disconnected, particularly when an audio signal is present, high-voltage transients may develop across the output transformer.
Under certain conditions, these voltage spikes could potentially damage the output tubes or output transformer.
For this reason, we strongly advise against allowing a powered-on tube amplifier to operate without an appropriate load, unless its manufacturer explicitly confirms that such operation is safe.
5. Can the LC30 be used for real-time A/B switching between two powered-on amplifiers?
We would like to clarify that the LC30 is not designed to support switching between two amplifiers while both are powered on, especially when one or both are tube amplifiers.
Such operation falls outside the intended operating conditions of the product, and we do not recommend it.
For safer operation, we recommend switching off both amplifiers before changing the selected amplifier channel. After completing the switch, please ensure that the selected amplifier is properly connected to the speakers before powering it on.
If you are using a tube amplifier, please also follow its manufacturer's specific instructions regarding speaker loads and power-on/power-off procedures.
Regarding your feedback and suggestions
We genuinely appreciate your suggestion that the LC30's product description and user instructions should more clearly explain these operating limitations, particularly for customers using tube amplifiers.
We understand your point that advertising no-load protection without clearly explaining which channel is protected could lead customers to misunderstand the scope of this feature.
Your feedback is valuable, and we will share your observations and recommendations with our product team for further review, including the possibility of improving the safety warnings and operating instructions.
Although we cannot promise immediate changes, please be assured that we take your concerns seriously.
We also appreciate the additional precautions you have taken to protect your tube amplifier. Your detailed measurements and practical observations provide helpful information for understanding how customers use the LC30 in real-world audio systems.
Once again, we sincerely apologize for any confusion or concern caused by the product information.
Thank you for your patience, your thorough investigation, and your willingness to share your findings with us. Feedback from knowledgeable and dedicated audio enthusiasts like you helps us identify areas where our products and documentation can be improved.
If you have any further questions or would like additional clarification, please do not hesitate to contact us. We will be more than happy to assist you.
Wishing you all the best!
Good to know. I did the same but with a 220-ohm resistor. Do you think I could safely go go up to 470-ohm? I'm not running live A/B comparisons. I just want a dummy load to guard against user error if I accidentally run my tube amp with the LC30 selected to the other amplifier.
If it matters, it's a 160 wpc tube amp. My other amp connected to the LC30 is a solid state amp so I'm not too worried about it.
It's not like you're gonna blow it up the moment you turn your amp on. Are you ever even using those 400W? :p
And parallel is just that, parallel. You run speaker cable to its input, from the amp and additionally to the speaker connection.
Like this:
Amp to Speaker.
Amp to LC30 Amp connection.
Or:
Amp to Speaker.
Speaker to LC30 Amp connection.
