Sjkrabbe
No you are not I have had nice times with his records since the first album came out in first half of the 1980s. Saw him live in concerts back then as wellSo I am not the only one on this forum listening to Wollenweider?
I use the TC clarity meter on a every day basis and it is SO great. I use it when Im mixing Radio broadcasts. When you have first tried it there is no going back. But it has only digital input, AES/spdifApples and pears. Having said that, TC electronic Clarity M seems to be good if you are in need of:
The CLARITY M provides a comprehensive set of precision tools essential to the success of any audio producer. Ideally suited to stereo and 5.1 mixing, mastering and post-production,...
TC Electronic | Product | CLARITY M
www.tcelectronic.com
But, what this device is supposed to be designed for ?
They can't be calibrated as it only measures a voltage and not power.Meters not calibrated? Rated poor. Guess I‘m too much German engineer.![]()
Right.....no way to really "Show" wattage as is is merely a calculation based on varying speaker load by frequency.People that like to see nice swinging needles and/or need a speaker or amp switcher.
and ... if you calibrated it to a certain speaker impedance it still would not show the correct power value.
and ... even if you calibrated it at a certain power level the scale is incorrect anyway so an indicated power level at a substantial different deflection than what you calibrated it to would still be incorrect.
The meter is just for fun (as mentioned by Amir in the review).
Power scale and dB scale are not 'matching' either so 1 or both scales are incorrect.
You could use it as an amp or speaker switcher, but not for >250W amps.
The 'safety load' of 390 ohm for the not connected amp can hardly be called a correct load.
It looks nice, needles swing up and down. That's what people will be buying it for while believing it truly indicates output power.
With this meter you could do that if the impedance at that frequency was known. Unfortunately it can only be correctly calibrate at a certain level but since the scale is not correct either indications at the same frequency would not be correct.You CAN show wattage accurately for a single point at one frequency with a test tone though.
But, again, NO "Watt Meter" can show actual wattage, as they all only show voltage.With this meter you could do that if the impedance at that frequency was known. Unfortunately it can only be correctly calibrate at a certain level but since the scale is not correct either indications at the same frequency would not be correct.
Sadly this device can not be used as a measurement device. Only as amp/speaker selector with some 'swinging needles'.
and @renaudrenaud are you guys talking about him: https://www.vollenweider.com/No you are not I have had nice times with his records since the first album came out in first half of the 1980s. Saw him live in concerts back then as well
what device is that on top of the RME?
Very cool. Thank you![]()
GitHub - retired-guy/WiiM-VU: VU Meter Display for WiiM
VU Meter Display for WiiM. Contribute to retired-guy/WiiM-VU development by creating an account on GitHub.github.com
Low current relays, would be interesting to see reliability.Some pics from Fosi marketing material on Amazon;
Amir has not tested Neohipo ET30 for switching.Honestly, the second set of cables doesn’t make the setup any uglier, so I don’t mind it at all. But more importantly, even though I lurk this site a lot and use Amir reviews as reference for any audio purchase, I don’t understand the first thing about load, impedance and etc. So I don’t know how safe it would be to use this with my tube amp (a Unison Research Simply Italy). According to an Amazon user review, at least, it’s not a great idea:
“Does not provide protective load for both amps.
If you are using a tube amp you will have to be very careful how you set this up.
Protective load is 250ohm not 390ohm.
Seems OK for SS amps but not recommended for tube amps.”
Edit: If I wanted a switch, I’d probably be better off with the Neohipo ET30, which measured great in Amir’s review. Again according to an Amazon comment, this one is tubes friendly:
“This unit fulfils its main purpose for me by allowing seamless switching between my tube amp and solid-state amp, since it still sends a small load to the tube amp when not selected, this eliminates the risk that comes with not feeding a signal to powered-on tubes.”
I found it interesting as well. What it seems to demonstrate is that low distortion at very high power requires well designed connectors which are clean, well made, properly plugged in and low impedance (and not ferromagnetic). If you don't have this, you get unexpected increases in distortion at the higher powers. However, these increases in distortion are probably not audible. The more "pedestrian" designs are less powerful and have higher intrinsic distortion, which again is probably not audible.Moving back on topic--am I the only one who finds it amusing that this little, "lowly," device is, "separating the men from the boys," with how it affects the higher-caliber amps like Purifi and Topping Bx00, but not the more pedestrian amps like ZA3
Wow, everyone bashing the meters??
I think "We all know" there is virtually no way to make an actual accurate "Power" meter, as speakers are not resistive loads.
But meters like this, beyond being "Fun", are a nice way to have a relative "idea" of how loud or how much volume of music....to criticize it seems a bit silly.
damoreengineering.com
Good point, he just measured the impact of the VU meter on the amp. I’ll definitely stick with my manual switching method. If it ain’t broke…Amir has not tested Neohipo ET30 for switching.
Just add 2 of those at $467 each and you are set![]()
AMM-1
The Audio Multimeter and Handheld Dyno. Measure TRUE amplifier power! Measure impedance of speaker boxes. Measure voltage drops, and much more! The purpose of this tool is to enable the user to: Measure True Amplifier Power output into any load reactive or resistive Measure Common DC...damoreengineering.com
