solderdude
And you connect that via a cable which adds resistance and inductance to the otherwise low output R of the power supply ?Hi everyone,
I’ve recently ordered an Ultra Low Noise Linear Power Supply, scheduled to arrive on March 27th. My goal was to find a high-spec LPS that offers the best "performance-to-dollar" ratio to see if further gains can be squeezed out of my current desktop chain.
While my Fosi already performs admirably with the stock switching supply (subjectively zero noise floor), I wanted to test whether a specialized power solution could offer any measurable or audible improvement.
Technical Specifications of Interest: The ZeroZone LPS-1706A caught my eye due to its ripple specifications. The manufacturer quotes:
Audio Bandwith Ripple (20Hz–20kHz): 1uV at rated current (12V/4A)
Full Bandwith Peak Ripple (1MHz): 4.8mV at rated current (12V/4A)
Internal Design & Architecture: The unit utilizes a MOS regulator and a significant capacitor bank—50 x Nichicon FW series "Gold" audio-grade electrolytics. The design philosophy here appears to be using a large array of lower value uF capacitors to achieve ultra-low ESR and faster charge/discharge cycles compared to a few massive cans.
The Test Plan: I’ll be performing some A/B listening tests between the stock wall-wart and the ZeroZone. I am particularly interested to see if the low-impedance configuration and fast power delivery impact low-frequency layering or soundstage transparency.
Beyond the Fosi, I also plan to test this with my Apos X Druid R2R DAC, as R2R ladder networks can often be sensitive to power supply fluctuations and noise.
I’ll report back with my impressions once the unit has settled in.
A bit like having an amp with DF of 10000 and using 5m of cable and having an inductor in series with the woofer.
