Fosi Audio DS2 Portable DAC & Amp Review
Rate this portable DAC & HP Amp
    Votes: 5 1.3%
    Votes: 5 1.3%
    Votes: 16 4.1%
    Votes: 367 93.4%
Um, they have. The Qudelix 5K has it's own battery. It works great for me in the car (via BT) where it's always plugged into a power source. The PEQ is icing on the cake.
I bought a Qudelix 5K, but it stopped working after two weeks. I tried contacting Qudelix support. No answer. I wrote an email, asked on their forum. No answers. In the end I sent it back to Amazon. So, no Q was not a good experience.
You probably know this but just in case, you can't use AP as the source for this device using ASIO4ALL. It will distort the bitstream. My non-sweep measurements were performed using Roon player with the test signal in exclusive mode to get around this. All USB audio devices in this class do the same thing.
it's one reason i asked @Fosi Audio what usb bridge they used here, since if it's Savitech or Comtrue there are native ASIO drivers you can install for them and maybe overcome that Asio4all limitation.
Why? How?
Why? Who knows?
I had white mailboxes and white wood posts. Maybe the color was an attraction?
I've seen other mailboxes which appear to have been damaged in my semi-rural region.
Thinking there are a very small % of people who indulge in vandalizing property?
I’m a get along with everyone person, so there’s no there, there.
How? It appeared as though it was hit by a vehicle judging by tire tracks that tore up my grass by the mailbox.
Have never used video surveillance and don’t plan to start.
I'm real ignorant so no one laugh, the gain on the amp is high level right (to drive high impedance headphones), does this mean it's less efficient driving lower impedance devices, it'll drain your battery more than if you were using that Sonata dongle that seems less maximized for high impedance phones?
It has an option for low and high. You switch between the modes by pressing both up and down volume at the same time. The indicator light changes when you do this.
It also changes color to show what quality stream is playing, but I never bothered to figure out what those colors mean. Fosi's manual is a little confusing about what the colors mean.
It's SA9312, made by Savitech.
Huh, interesting, it's not even being mentioned in the user manual.
Terrible color choice for an online manual, but here is where it is mentioned:
Edit: Forgot to include the link.
That's for the old version DS2 with ES9018K2M chip, it won't work with the CS chip one. (2024 Ver.)
Stated in specs: High-low gain mode change - Not available
