About hd490pro I've seen one post somewhere forgot where that guy tested the Fosi ds2 the CS version with sundara (measures 300ohm~) balanced vs his macbook pro (silicon) and got comfortable volume of 89% on macbook and 55% volume on ds2 balanced. Since hd490 pro is half the impedence 130ohm should be good enough I think.First of all, just a quick heads-up to those considering getting the DS2 specifically through Aliexpress: I bought one that was advertised as the DS2 DS512 model, which comes with the ESS9018K2M chip, presumably the older version. What arrived was clearly the newer dual CS43131 configuration. It says so in the included user manual, and I've manually confirmed that pressing both volume buttons at the same time does nothing (no separate low/high gain modes). Now, for me this is not really a drawback; however, those specifically wanting one version over another should take the information listed by third-party vendors with a big grain of salt! As for the power output, it is listed in the included manual as SE 128mW (32Ω) / BAL 170mW (32Ω). (The ESS version I thought I bought was advertised as having a balanced output of 510mW, but who knows if that was ever really the case?)
Finally, I have a question that I hope someone here can answer. If the balanced output merely offers 170mW compared to 128mW SE, how much additional headroom are you realistically getting in terms of volume? I’m another 490 Pro owner, and my EQ settings have a preamp gain of -6.8 dB. Will going balanced make much of a difference?
(EDIT: I found the review)
