Fosi Audio DS2 Portable DAC & Amp Review
Rate this portable DAC & HP Amp
    Votes: 6 1.5%
    Votes: 5 1.3%
    Votes: 17 4.3%
    Votes: 371 93.0%
Wouldn’t this make more sense than the SMSL su1 if you just need an usb input DAC?
In such scenario, as a pure dac, a single ended one with no volume control like Jcally JM20 will be cheaper and would make even more sense.
I am a little surprised by the lack of interest in whether the balanced out of the DS2 is actually connected to a common ground - surely this is important for anyone wanting to use the balanced out as - a balanced out.
UPDATE: Fosi contacted me and said there is no stock, and asked if I am happy to wait, which of course I am.
No info on whether the balanced out has a common ground though.
You can get them through AliExpress for $73, two weeks delivery to Sydney:
I bought mine from them no issues.
Do we have measurements for it ?
Here's 1kHz SINAD and THD+N vs Output power at 32Ω:
JCally JM20 1kHz SINAD.png _b_THD+N vs Output Power at 32Ω __b_(Both channels driven, Right channel measured, 20Hz to 20k...png
If I'm using this as a desktop DAC and have RCA inputs on my amp, will there be any difference using the 4.4 balanced vs 3.5 to RCA adapter? No right?
Holy Hell
We are truly living in a golden age of Audio. $55 for this level of performance is utterly amazing. Many people don't need any other DAC in their system.
PEQ is tough with Macs.
Not really.
You can use the apple AUnbandEQ plugin with Sound Source, or any other audio unit plugin host. Job done.
Don't need this at all, but felt compelled to buy after reading the reviews. I picked up two from eBay:
Are you also connecting to active speakers?
In such case, the SU1 has an optical input that you can use to break ground loops.
If not, then absolutely, I think this is the cheapest device with this kind of performance while also being very small.
Or use the balanced output - assuming your active speakers have balanced inputs.
You cannot connect a 4.4mm balanced output to an RCA input without risk of deteriorated performance or damage to the DAC.
Use 3.5mm.
Holy Hell
I use my DS2 with a pair of HiFiMan HE400SE, and added Amir's EQ profile and a balanced cable. I use this with an iPhone as my mobile system, in the car and when walking. Performance is really excellent, all for under AU$200. It really is a golden age of Audio HiFi!
I already have great performing dongles, It won't sound much different,........I don't really need it.....................ordered! ....I am a lost cause
why ordering it even though you`ve had some?
Fair question. Many of us admire the engineering of audio devices and collect more gear than we need.
Got mine today.
A quick test on my Iphone and now it is connected to iLoud Micro Monitors and I am impressed !
Nice little piece of gear !
I got mine today too. Sounds great...but experiencing occasional dropouts with Windows 10.
I'm using it with Roon and Ropieee endpoint on RPi.
I am gonna test it tomorrow with Windows, and maybe MacOS.
Have you tried sending an email to UAPP's developer?
He's usually super quick to respond and patch issues.
Not yet, I am going to try a few things on my side when I have time. You are correct - the developer is usually quick to respond - I had a HiBy R5 Saber early on and exchanged a few things with him regarding support of that device and a couple of issues I was seeing. He fixed them in the next release.
