Precisely because of this reason.Maybe because it has digital volume control and not a potentiometer?
Made me laugh but I can understand your frustrationAnyone know how to disable the bluetooth on it ? I live in an apartment building, and some neighbours are connecting/pairing to my amp and playing their music......pretty anoyingI dont even have the antenna installed, but it still picks up their phones aparently.
Just an idea but do you know if the Fosi allows Multipoint pairing? BlueTooth pairing usually means that only one device can be paired at a time, so if you pair the Fosi with one of your phones/whatever, others cannot then pair with it, unless it allows Multipoint.Anyone in range can pair to the AmpI opened it up, and pulled the little wire going from the board to the antenna socket in hope that it would reduce the range, but it is still about 4-5 meters....and that is enough for someone to connect if they are out in the stair case, or above or below my apartment. Will have to talk to my neighbours if next time it happens. It auto connects when they are close by. I have long pressed the volume button, to delete the pair. Will see if they try to connect again. Pretty sure they do it by mistake, as I can hear their phone conversations, and music blasting through my speakers. Its in arabic, so I unfortunatly dont understand
You think shorting the antenna is ok ?
lol! nevertheless,i am and have been having contented and fulfilling times with class d, several, and a 3e a5se just landed a couple days ago too. this after decades literally, since 1989, happily powered by sansui sx-900. dad had leaks with goodman speakers and a collaro turntable at home in akl nz during the 1960s, come to think of it...adiósThe comparison with the tube amp at the end.... brutal. The class D amp sounded like someone squeezed Nora's throat with both hands and forced her to sing at the gunpoint. Ouch.
I'm seeing a substantially lower price, at least in the U.S., with their initial 20% discount code applied...and there is the choice of three different power brick options, which can influence the price. But not sure if that factors in tariffs.
Yeah, I like my SMSL AO100 because it does have an internal power board, makes it a nice compact unit.Not alot different if a wiim amp pro didn't have streaming only bt
BUT why a laptop power supply ? Why not inside of the amp like wiim amps ?
It cuts down costs quite a bit to have it seperateNot alot different if a wiim amp pro didn't have streaming only bt
