Yes. It is difficult to read, but I think he is describing **a sequence of several separate modifications**, some electrical and some component substitutions. He then attributes an improvement in sound to the collection of changes.
As I read it:
1. **First-stage op-amp changes**
- Original X5: apparently **OPA1612**.
- He previously changed this to **OPA2228**.
- He has now changed it again to **OPA2156**.
- He may later try **OPA1656** here.
- His reasoning is that bipolar-input op-amps have input bias/current-noise characteristics that he thinks are undesirable with an MM cartridge. He regards the OPA2156 CMOS input as better suited.
- Claimed result: *“OPA2156 is amazing”* and the X5 sounds better with his AT-VM95.
2. **Output buffer op-amp**
- Changed **LM4562 → OPA1656**.
- Again he says this contributes to the X5 sounding better, but doesn't separate the audible effect of this change from the first-stage change.
3. **Input capacitance changed**
- He says he replaced the X5's **10 pF input capacitor with 15 pF**.
- He calculates total cartridge loading as roughly **142–157 pF**, made up of:
- RCA cable: 87 pF
- X5 input capacitor: 15 pF
- X5 PCB: 5 pF
- turntable PCB: 15 pF
- OPA2156 input capacitance: ~5 pF
- turntable internal wiring: 15–30 pF
- His aim is to get closer to what he considers ideal loading for the AT-VM95.
There is a confusing bit later where he says the **original X5 has a 150 pF input capacitor**, despite earlier saying he changed it from **10 pF to 15 pF**. Those statements don't appear compatible unless he is talking about two different capacitors or has mistyped one of the values.
4. **Subsonic filter capacitors**
- Replaced the first pair of green bipolar capacitors with **4 × 1.5 µF Wima MKP film capacitors**.
- He describes this as modifying the basic subsonic filter.
5. **Output-buffer feedback resistors**
- Changed the feedback resistors around the new OPA1656 output buffer to **2 × 220 Ω**.
- He doesn't clearly state what he is trying to achieve with this change or give an isolated result.
6. **Last pair of bipolar capacitors**
- Apparently left in circuit, but each is bypassed underneath the PCB with a **150 nF MKP capacitor**.
- Again, no separate measured or audible result is stated.
7. **First-stage gain altered**
- Changed resistors from **15 Ω to 22 Ω**.
- Says this makes the first-stage gain **26**.
- He then uses the rear switch at the nominal **48 dB** setting but says his resulting overall gain is actually about **45 dB**.
- The purpose seems to be increasing overload/headroom with his MM cartridge: about **15–16 mV peak** before reaching a nominal 2 V RMS output, or about 20 mV if the following equipment can accept roughly 2.5 V RMS.
Then comes his overall diagnosis of the stock X5. He thinks there are **two main design problems**:
- **Too much cartridge loading capacitance**, which he says shifts the AT-VM95 electrical resonance downwards and causes its poor/sibilant HF sound.
- **OPA1612 as the first-stage amplifier**, because of its bipolar input, bias current and current noise.
The first of those at least describes a mechanism which **can genuinely alter the frequency response of an MM cartridge**. Cartridge inductance and total load capacitance interact, so changing capacitance can produce measurable changes in the upper frequency response. That is quite different from simply swapping op-amps and claiming one “sounds better”.
The thing I would want from him is measurements. In particular, **frequency response of the cartridge + X5 before and after the capacitance change**. If his claimed original capacitance really is high enough to badly load the AT-VM95, that should be very easy to see.
His op-amp claims are much less convincing from what he has written. He provides no measurements showing that the OPA1612 was causing audible noise, distortion or frequency-response errors, nor that replacing it with OPA2156 improved any of those sufficiently to be audible.
So buried in all the op-amp rolling and capacitor swapping there *may* be one genuinely interesting modification: **correcting excessive MM cartridge loading capacitance**. The rest needs measurements before I'd attach much significance to the claimed sound changes.
