Great Pre and post to demonstrate, once again, the subtitles importance.
This is not a audio Impressions review, neither a audio science review but rather a audio gear review, as in the subtitle:
For a list of reviewed audio equipment, click here.
That said, the Fosi team as been always sharp about the forum members remarks, so we can expect that a new x-box will be better than the already honest x-5.
I bought an X-5 (for my mother's system [DUAL 1229 to FOSO X-5 to TAPE in) that uses an ADVENT 300 RECIEVER pre outs to a pair of Bridged mono NAD 2100's (specs here):
Specifications
POWER AMP SECTION
Model:
Monitor Series Power Amplifier 2100 Power Envelope - NAD, New Acoustic Dimension;
- Dimensions (WHD)
- 435 x 108 x 381 mm / 17.1 x 4.3 x 15 inch
- Notes
- A 2 x 50 watt (150 watt Bridged Mono) hi-fi stereo Power Amplifier in NAD's Monitor Series of hi-fi separates. With a high-voltage, high-current output stage enabling it to deliver well above its rated power to handle musical transients, and a 'soft clipping' circuit which gently limits the waveform voltage when the amplifier is driven beyond its rated power.
On the rear, Normal-In and Lab-in sockets for connection to a pre-amplifier, (Lab-in has a wideband frequency response), switches for Input (Normal or Lab), Soft Clipping (On/Off), Bridging (On/Off), and a Speakers Impedance switch (Normal 4Ω / Hi 8Ω), (the Hi setting can be used where one pair of speakers are connected and impedance is at least 8Ω, this re-optimizes the amplifier for maximum power). Some models have a switched and an un-switched AC outlet.
On the front, push button for Power, Speakers A, B, rotary controls for Left/Mono and Right Input Level, LED indicators for Power, Protection and Soft Clipping and a jack for headphones.
Specification
Stereo Mode
Continuous Average Power Output into
8 ohm (Min, RMS power per channel
20-20kHz both Channels Driven
with no more than rated distortion) .......: 50 W
Rated Distortion 20Hz-20kHz ...............: 0.03%
Clipping Power (Maximum continuous....: 70 W
power per channel)
IHF Dynamic Headroom at 8 ohm .........: +6dB
IHF Dynamic Power at 8 ohm ...............: 200 W
(Short term power) at 4 ohm ...............: 250 W
at 2 ohm ...............: 330 W
Damping Factor at 50 Hz (Ref. 8 ohm) ..: 100
THD 20Hz-20kHz from 250mW to rated : <0.03%
Frequency Response, Lab input ...........: 3Hz - 100kHz, +0db -3dB
Signal to Noise Ratio A-weighted .........: 100db ref 1W, 117dB at rated power
Bridged (Monophonic) Mode
with no more than rated distortion) ......: 150 W
IHF Dynamic Power at 8 ohm (max.......: 500 W
(Short term power) at 4 ohm ...............: 660 W
speakers out to a speakers in on a 12" ported sub toned to 34 HZ, speaker out (200 HZ high pass) to a pair Radio Shack WOOD BOX Minimus-7's.
It's "good 'nough" for her 92 year old ears (and she can ADJUST the Bass & Treble controls to taste in the large, multi-angled walls, cathedral ceilinged living room) for her Austrian/German folk music albums. The unit is also pretty good at receiving the FM stations tat she listens to (with an antenna mounted at the top of the second floor chimney).
It's not always what the gear is capable of but sometimes what it is capable of within the constraints of what you can hear. Of course, you still need adjustments to make it the best it can be for you.
This is the test of my mother's ADVENT 300
Since the Pre Out nor the tone controls were not tested (not the fault of the reviewer, as I did not ask for it to be tested that way: that it wasn't tested that way is entirely on me), we really don't know what she is getting for her use case (we can only surmise that it's better than her ears).
[IMG alt="amirm"]https://www.audiosciencereview.com/forum/data/avatars/m/0/2.jpg?1477370459[/IMG]
JoinedFeb 13, 2016Messages49,494Likes293,444Location
This is a review and detailed measurements of the Advent Model 300 Vintage Receiver. It is on kind loan from a member. I believe it came out in 1970s. The original cost was US $270. That would be $1,300 if adjusted for inflation.
I love the tuner knob on the 300, reminding me of what you would find in a HAM radio:
There is no detent on various tone adjustments and balance. The slide switches are par for the era but don't feel nearly as nice of Japanese gear of the time.
The back side is decidedly cheap:
Those tiny speaker screw terminals were on the cheapest 8-track tape/receivers, not on serious hi-fi. The RCA terminals all look tired but work.
Receiver Audio Measurements
I opted to use the Aux input for my testing. I used an RCA cable to feed the pre-amp to power amp. Not sure if they came with a special shorting connector or not. Let's feed a 1 kHz tone to the 300 and see what comes out:
Distortion is below 80 dB but because we have a lot of power supply harmonics, it degrades SIAND to just 68 dB which places the unit pretty low in our amplifier rankings:
Signal to noise ratio is poor due to aforementioned power supply noise:
These are yesterday's amplifiers so don't look for hundreds of watts into 4 ohm load:
Yes, just 23 watts! No wonder the unit runs so cool in use. If we allow distortion to peak higher, we still don't get much output:
Switching to 8 ohm load reduces available power even more as it normally does:
Ironic though that it has less noise than a modern AVR, albeit, not a very good one (NAD T758).
Pre-amplifier Performance
I disconnected the power amp and measured the output of the preamplifier using our 1 kHz tone and got this:
Distortion is similar to when we were driving the power amp but noise is much lower so SINAD improves 10 dB.
EDIT: by request, here are the phono input measurements.
Phono Input Measurements
As usual we start with our dashboard:
Distortion is quite low at -90 dB but SINAD suffers due to high level of noise where the gain is the highest (low frequencies).
RIAA equalization is very good except for the high pass filter which is causing some peaking:
Here is the saturation point vs level:
And how distortion (
no noise) varies with frequency:
We see a typical rise with frequency but there is also some increase in low frequencies, likely caused by the peaking of the level there.
The inefficient speakers of today won't be kind to the Model 300 due to lack of power. With non-competitive noise and distortion, there is not much of a reason to use this amplifier. It does have a vintage look though so perhaps someone would be interested in that aspect of it.
And yes, it is possible that the power supply noise is higher due to age. I can only test what I am given.
