Fosi Audio Box X5 Phono Preamp Review
Rate this phono stage:
    Votes: 7 2.5%
    Votes: 10 3.6%
    Votes: 51 18.5%
    Votes: 207 75.3%
I have found no indication about input impedance value for MM and MC cartridge...
This is available with some others, or are you asking for Fosi to offer it?
Fosi X5 natually, this thread is about it. I could even pay 5€ extra for it, no switch needed!
I do have a low budget preamp with filter. As well some integrated amps have it.... but now I need a new/second preamp for my living room system. Cables from deck must be 3m long, so external preamp is mandatory. ProJect Phono Box S2 is much more expensive. My cartridges are all MM
Thank you for the review.
What a cracking little box: neat, inexpensive and measures really well. I'm enjoying Fosi's simple but effective designs too - who knew I'd like orange so much!
I keep telling myself I'm over vinyl ... and now I'm wondering about an office turntable setup. I need to have a word with myself.
@Fosi Audio
Thank you for this nice product.
Maybe Fosi wants to whip out an ASR discount, because now, many of us need a new phono-stage :cool:
I mean, the thing is $100. Do you really need a discount? The margins on this can’t be great so I don’t know how much further Fosi could nudge the price down anyway without losing money.
I've been wondering, does the Audio Precision analyzer have a test routine for (phono) preamps like this or is it the standard test routine you're using @amirm ?
I don't know if they ever had scripts for phono stages but they certainly don't have one now. I have developed these tests over time. Fortunately AP still has reverse RIAA equalization which is critical in these tests. I wouldn't be surprised if at some point they delete that functionality.
Interesting! How is the reference level of the generator for these tests adjusted inside the AP? You need a very low-level sweep to test these devices after all. Does it have relais that put resistors in the signal path?
This is a review and detailed measurements of the Fosi Audio Box X5 stereo Phono stage. It was sent to me by the company and costs US $109.99.
Company manages to bring a touch of class in a category that is universally utilitarian with those rounded corners and orange power button. Flexibility is provided by supporting both Moving Magnet (MM) and Moving Coil cartridges with different gain settings:
The gain setting is sandwiched tightly between the input and output RCA jacks. But company has wisely put in a tall knob to allow for relatively easy adjustment.
I forgot to take a picture of the AC transformer that is rated at indicated 16 volts.
Fosi Audio Box X5 Phono Measurements
It was quite a pleasant shock to see complete lack of distortion in our dashboard resulting in superb level of performance:
If the mains noise was not there, it would likely do even better. As is, it essentially ties with the best phono stage tested:
Moving coil at much higher gain naturally has more noise but still respectable:
Also impressive and very important, RIAA equalization is superbly done:
What's more there is good bit of headroom into treble region (my standard is > 100 mv @ 1 kHz):
Measuring distortion alone, we see that it is vanishingly low, at the level of good DACs and much better than many phono stages:
There are a lot of value oriented phono stages. Fosi innovates by bringing best in class performance while packaging the unit in an attractive enclosure while keeping the cost very reasonable. There is nothing more to ask!
I am happy to recommend Fosi Box X5 phono stage.
A long time ago I built my own phono preamp from an AES article using discrete transistors. So I'm always interested in updated designs. I did an image search for Fosi Audio Box X5 teardown with no success. Very good performance.
Very nice work. Credit where credit's due in spite of competition!
I'm guessing from my own experiments with similar results that this is based on an NJM4580 front end.
The low price of the Fosi tells us that that the components can't be too expensive, just that they've optimised them with SOTA design. It must be tough competing with things like this, even though you do offer more.
i have a parasound jc 3 jr i use in my system. They claim "signal-to-noise ratio of up to 94 dB, with a THD less than 0.02%".. wonder how it measures on Amir's bench?
It is lot of fun but you have to spend some money in this. A nice turntable, a good cartridge, a phono preamp.
Then comes the cleaning brush. Add a new mat, a protractor, an ultrasound cleaning machine, and the records. Don't forget these little bubble levels and the cartridge weight gauge.
Every 20 minutes you need to move because it is time to listen to B side or another record.
Yes, not comfortable, expansive and the quality is far below what you can have with some inexpensive DAC.
Maybe the same mental process as smoking. It is killing you but you like it.
