Forward Backward IIR EQ
JulianW
Forward–backward IIR filtering appears to offer zero-phase behavior with much less pre-ringing than linear-phase FIR EQs.
This almost sounds like a “free lunch” what am I missing? Where are the hidden compromises compared to FIR?
A big one is that FIR can be applied (with some delay) to a continuously playing signal. Forward-backward IIR requires the whole signal to be pre-processed before playing.
And regarding pre-ringing? Is nature being tricked here?
No.
According to whom?
No "free lunch" in signal processing (except perhaps in computational efficiency and numerical stability). Same magnitude and same phase means same time domain behavior; filter implementation does not matter.
As has been mentioned, forward-backward IIR filtering is only possible offline because the filter is non-causal and infinite length. For real time use, one can truncate the forward-backward IIR filter to some finite length, yielding (wait for it...) an FIR filter. In principle, this happens any time you apply an IIR filter to a non-periodic signal because the result must be truncated. Hence, the idea that FIR must somehow produce a different result is incorrect by definition.
