- Thread Starter
- #41
Gigabytes. So not much in today's computing but in the context of a virtual server with X amount of RAM and CPU threads, it costs good amount of money.Gigabytes or terabytes?
y wife and i feel bad about it
wow! is it possible to rebuild or compress that table?Ironically, the table for all the likes has grown massively as well! It is in the top 10 larges files! But I happily accept that.![]()
It is scary stuff to mess with the forum tables and risk corrupting something that you won't find until days or weeks later. Someone who is more fluent than me in SQL could do it, assuming there is something to be compressed.wow! is it possible to rebuild or compress that table?
Yep, I used pretty standard Splitters that were relatively cheap and had no issues with Comcast.Understand that, but extra hardware is needed to split the signal for cable boxes at each outlet, and I know there were problems in the past with Comcast and MoCA (based on a quick search today). I'll look at ActionTek.
Yep, I got full gbit on my ActionTek units. I bet I still have them... should post them for sale since I have no use for them anymore.... but I would have to find them first haha.I use some of the ActionTek devices. Not had problems, but that doesn't mean no one does. It is a neat solution to houses with coax. I've used them where someone had cable and is now streaming, but you have the coax going everywhere already so good solution for a 1 gpbs or 2.5 gbps connection. I've generally gotten at least 80% of the claimed speeds.
Not too bad. Are you running this whole forum on a VPS? Or does the server you rent only have a single 256GB drive? Most server rentals today have 512-1024GB.160 Gigabytes.
Sure, but you can always back up first. Make the changes and then re-import the table if it doesn't work out.It is scary stuff to mess with the forum tables and risk corrupting something that you won't find until days or weeks later. Someone who is more fluent than me in SQL could do it, assuming there is something to be compressed.
What is the solution and how much does this solution cost?It is scary stuff to mess with the forum tables and risk corrupting something
I have already provisioned a 240 gigabyte server. Just need to move everything over.What is the solution and how much does this solution cost?
Correct.Are you running this whole forum on a VPS?
In my small way, I will soon renew my donation.I have already provisioned a 240 gigabyte server. Just need to move everything over.
What kind of arcane hosting is this running at? Any decent VM system allows to simply expand the virtual disk and grow the filesystem if needed.I have already provisioned a 240 gigabyte server. Just need to move everything over.
It is digital ocean. We had get a new server because we are change OS.What kind of arcane hosting is this running at? Any decent VM system allows to simply expand the virtual disk and grow the filesystem if needed.
This could be solved easily if we start posting only subjective impressions and audiofooleries.Ironically, the table for all the likes has grown massively as well! It is in the top 10 larges files! But I happily accept that.![]()
160 Gigabytes.
Wild that you run the whole thing on a VPS.... I would put this on a dedicated server for sure.It is digital ocean. We had get a new server because we are change OS.
VPS should be insanely affordable, like under $30/mo max.What is the solution and how much does this solution cost?
It is not clear what we are running on. It certainly is not marketed as a VPS as we have actual core, memory and storage. And I manage it as if it is a raw hardware (no cpanel, etc.). I thought we were running on native iron but some of the later offerings they have make it seem like we are somewhere in between VPS and real hardware.Wild that you run the whole thing on a VPS....
As you know, the trick is how over subscribed a VPS is. In the last forum I did, we were on real VPS and performance was extremely variable. With DO, it is quite consistent. DO is very reasonable as far as cost. There are one or two outfits that are cheaper but there are many complaints about over subscription. Our new server costs a lot more than $30 a month.VPS should be insanely affordable, like under $30/mo max.
Have you tried ElasticSearch?
Well if you do cat /proc/cpuinfo then you will see which cpu it is and you can see if it's virtualized. But if you haven't paid for a specific spec; then it's definitely virtualized.It is not clear what we are running on. It certainly is not marketed as a VPS as we have actual core, memory and storage. And I manage it as if it is a raw hardware (no cpanel, etc.). I thought we were running on native iron but some of the later offerings they have make it seem like we are somewhere in between VPS and real hardware.
Just do it like the bastard administrator from hell.Our server is near max space so the indexing system has decided to shut down.I have messed with it for a few hours to override to no avail. Search still works but as of what was here a week or so ago.
I have provisioned a new server with double the storage but have not had the opportunity to bring it online. Plan to do so next week.
Note that this also impacts searching for yours and other people's posts.
