Zek
- Joined
- Feb 17, 2018
- Messages
- 1,890
- Likes
- 2,474
Install Google Translate in your browser and with one click you will have a translated page.sadly i don't understand german![]()
That's nearly impossible for the specific configuration,or for any custom one.hi
might you please help me to customize?
thanks
I do see a similar config for Mac,maybe ask them there for guidance?Im jealous as I run a Mac and you cant use the GUI in Foobar.
I believe a lot of Mac users would come over to Foobar as itunes or "music" has its limitations.
itunes great on portable devices but not as a main interface for digital source material.
If any Mac users are able to chime in if the have found an acceptable GUI example that comes close to the PC version.
Maybe I haven't read the instructions correctly?
Thanks for that, appreciated.
I believe that sound-wise both will be the same,no doubt about it.Thanks for that, appreciated.
I believe you run it under a Windows app shell which involves two further programs. Messy and really still wont meet the same level as the PC version.
The Mac version is very limited but would work just like itunes from a GUI perspective.
There must be a good reason why the developers are unable to replicate the Mac version to the high standard of the PC version.
Never mind, cant have everything considering Foobar is free. Really impressed with a number of people willing to put so much time into free software which is also being constantly updated. VLC, REW etc.
What are you talking about? Your thread is right here:Replies to my thread where not helpful, then it was deleted to help with spam? even though it would have helped many people I have no doubt...
www.audiosciencereview.com
I have been using foobar2000 for many years, and I have listened to this track many times, and it sounds great with foobar2000 v2.24.4 [32-bit] with ASIO+DSD Output 0.4.6 componentIF some tracks have noise in the background with FooBar2000 and your using Default settings you can go into FILE at top LEFT corner, click preferences and choose Gain setting tab to be none.
Metallica For Whom The Bell Tolls was extremely noisy with much static noise until I turned gain setting to none.
Tidal has the same issue with this song so maybe check gain settings if you have Tidal also.
