I figured this is the best place to ask as you folks are the audio gurus and i most definitely am not one.
Ive recently come into some issues with my Focusrite 2i2 Gen1 where it likes to occasionally disconnect with my PC complaining that the device is misbehaving and will refuse to let it reconnect till i completely power off the system. It doesnt happen a lot but still its caused me some concern as the Gen1 is fairly old at this point and Im not exactly equipped to buy a new one just yet.
Im curious as to how the Gen1 compares to the Gen3, I know the mic/instrument inputs on the Gen1 have some problems with clipping even at low gain but beyond that Im not sure. Im mostly curious because my motherboard is a Gigabyte board similar to the one reviewed here https://www.audiosciencereview.com/...te-z390-aorus-motherboard-audio-review.13083/ except with the 1220-VB which is supposed to be slightly "better" but ill assume theyre mostly the same or close. Id like to gauge the rough difference between my motherboard audio and the Gen1 but i can only find info on the Gen3 which i cant use because of its not being USB standards compliant so on Linux it causes some funny business using newer Focusrite products.
If anyone has some information they can give me Id much appreciate it, the 2i2 i have mostly works for the moment but If i can have a passable solution for the dropouts with my motherboard in the mean time till i can get something like the Motu M4/M2 when theyre not 500$+ because theyre oos.
