digicidal
Overpriced as they may be... I definitely can't fault MSB for the build quality on any of their products. I just wish the cost was about 85% less.
Motu M2 seems to be so much better deal for about the same price
Only referring to the measurements (THD+N, SINAD a.s.o.) it's hard to say. Per specs https://cdn-data.motu.com/manuals/usb-c-audio/M_Series_User_Guide.pdf the THD+D is not so impressive: -97 dB (< 0.0014%), unweighted.
However, I'd like to see this on the bench, especially that Motu has a great reputation. I'd also love to see some inside pics too.
M2 also has more features as well:And the Motu M2 is a very recent offering. I too would probably choose it over a 2i2 or 2i4 at the moment if in the market for such a thing. Motu M4 is from the same family of products as well.
the trs outputs at the back would be ideal with trs-xlr cables to my monitors
I see. Cool. Mine is an Eris. Do you also use the headphone out and if you do, do you find it lacking? My local audio shop has both Focusrite and Steinberg, planning to demo them.That's exactly how I have my Mackie's connected to Focusrite now.![]()
Would you do some loop back measurements when you receive it? Like using arta or rew?I had no idea Motu released a new series of interfaces. Currently still using the Scarlett 2i2 Gen 1. Been wanting to replace it for a while with something "better", but all the Motu gear I just found too expensive. But this new entry-level stuff should be good, with good driver support (someting most of the other brands lack). Just ordered the M4!
As far as I know all three versions measure very similarly.Do we know what kind of performance differrence there is between the different versions (1, 2 and 3)? Perhaps most importantly differences to the ADC and mic pre-amp
I've been using the Scarlett 2i4 with Windows 10 volume control at 80% for Youtube, Bandcamp, etc.
Do you think 100% would be ok, or a bit less is safer, according to those measurements?
