SMJH
- Joined
- Mar 21, 2025
- Messages
- 75
- Likes
- 27
For anyone that read the 4th Gen 2i2 Review and is curious about how the upper-end of this generation fares, especially when it comes to output volume peculiarities, given 16i16 and up all use a digital volume control instead of analog: Here are my own 16i16 measurements. I simply downloaded and used Multitone Analyzer on the spot, with no prior experience, so please, if you find something odd, do let me know and I'll rectify it.
SETUP
NOTES
DATA
Preset: 1Khz Distortion Panel
Preset: IMD CCIF 19k + 20k
Preset: IMD DIN 250Hz + 8Khz
Preset: IMD SMPTE 60Hz + 7Khz
Preset: Jitter J-Test24
Preset: Multitone 32
Preset: Multitone 500
at -60dB output volume (from the interface output volume knob)
at -25dB output volume (from the interface output volume knob)
Apart from the obviously lowered SNR, I do not see an increase in harmonic distortion on the 16i16. If you've got a better way to test for it, please share it with me, and I'll re-measure!
SETUP
- Output: Monitor '1', Corresponds to main monitor output, left channel for this interface. Volume was maxed unless specified.
- Input: Line level '3', Corresponds to the first line level input (no mic pre) for this interface. Volume was maxed.
- Sample Rate: 48Khz In + Out
- FFT: 1M on all tests except last two (because I forgot! But it doesn't matter much anyway for those)
- Preset modifications: None outside of sample rate, wait period and FFT.
- Chart Units: I ran 1 test then calibrated Volts(ms) FS to '4' and did not touch it since, I'm not sure why I did that to be fair. This is why the leftmost panel reads '2.2468'.
NOTES
- I tried almost all IO to check if they have similar performance, and they do, apart from the inputs with preamps obviously. I can share measurements for those if you wish.
- I also tried multitone and 1Khz distortion tests at 44.1, 176.4 and 192 Khz, and found no difference compared to 48Khz, which is good. This also means whatever Focusrite Control 2 software is doing in regards to its 'Mixer' functionality is completely transparent. For those unaware, the always-on mixer included in the driver only works with sample rates at or below 96Khz.
DATA
