Mind to share the track list?On the question of spatial qualities, this is *hugely* dependent on content. I have collected a library of content for headphone testing which shows this effect.
Worse yet they seem to shift with position on my head. Have to get them in exactly the right place each time for my EQ to sound right.Definitely this.
The peaks and troughs are much more likely to be shifted in frequency and magnitude on different heads and rigs rather than simply disappear leaving a smooth response.
Hello Amir, can you share your list?On the question of spatial qualities, this is *hugely* dependent on content. I have collected a library of content for headphone testing which shows this effect. Without it, it is easy to conclude that there is no such thing.
Also, frequency response in 1 to 3 kHz is a large determinant of this effect. Take any headphone you have and boost this region and listen for spatial qualities. Likely you hear the effect (ignore the tonality difference -- just listen for externalization of the sound).
Spatiality seems to be software related: https://github.com/jaakkopasanen/Impulcifer
Oh no, you should have confidence in your knowledge and dedication! I wouldn't do it if you paid meIf I shared my list then any of you could do these reviews and I would be out of a job!!!
Focal Utopia APO EQ Score 1 96000Hz
April062021-104623
Preamp: -5.9 dB
Filter 1: ON PK Fc 30.5 Hz Gain 5.87 dB Q 0.67
Filter 2: ON PK Fc 198 Hz Gain -3 dB Q 1.09
Filter 3: ON PK Fc 1264 Hz Gain -3.85 dB Q 1.91
Filter 4: ON PK Fc 1993 Hz Gain 3.67 dB Q 4.25
Filter 5: ON PK Fc 2737 Hz Gain -2 dB Q 3.89
Filter 6: ON PK Fc 4005 Hz Gain -2 dB Q 6.11
Filter 7: ON PK Fc 5914 Hz Gain -7.08 dB Q 6.5
Filter 8: ON PK Fc 7794 Hz Gain -1.5 dB Q 6.25
Filter 9: ON PK Fc 8911 Hz Gain 5.68 dB Q 0.52
Filter 10: ON PK Fc 11520 Hz Gain -8.38 dB Q 6.5
Focal Utopia APO EQ Score 2 96000Hz
April062021-105103
Preamp: -5.8 dB
Filter 1: ON PK Fc 31.3 Hz Gain 5.87 dB Q 0.67
Filter 2: ON PK Fc 202 Hz Gain -3 dB Q 1.09
Filter 3: ON PK Fc 1266 Hz Gain -4.85 dB Q 1.91
Filter 4: ON PK Fc 1994 Hz Gain 3.17 dB Q 4.25
Filter 5: ON PK Fc 2799 Hz Gain -2.58 dB Q 4.89
Filter 6: ON PK Fc 4005 Hz Gain -1 dB Q 6.36
Filter 7: ON PK Fc 5943 Hz Gain -6.08 dB Q 6.5
Filter 8: ON PK Fc 8001 Hz Gain -2.5 dB Q 6.24
Filter 9: ON PK Fc 9264 Hz Gain 5.75 dB Q 1.16
Filter 10: ON PK Fc 11517 Hz Gain -9.38 dB Q 6.5
Other than Yamaha in the 70s, it was pretty much obscure outside of Paradigm and JM Lab speakers for many years. I think the Beryllium hype really started with the release of the Revel Salon 2 in 2008. Once Harman International's marketing machine got behind it, it became the new "It" thing, which started the beryllium arms race, everybody and their mother jumped on it, spawning a bunch of "me-too" beryllium flagships culminating with TADs ultra expensive Reference line.
Yes, you can muck about with the signal to affect spatial effects. Most likely they use a whole range of effects though, not just single and constant EQ adjustment.Spatiality seems to be software related: https://github.com/jaakkopasanen/Impulcifer
That software did not "invent" this effect but is merely (re)producing it. Nonetheless, it's interesting, we already have 7.1.4 simulations available, which probably can beat many a couchsurfer's surround set XP-EXT1 | EXOFIELD THEATER|Heimkino Sound System | JVCIm sure it can be modified via software but its also inherent in some music through some headphones with some people. The mix and extent I am sure varies. It cant be only software related if one perceives spatial/ soundstage properties without software involvement.
Interestingly, many open-back headphones also have those spikes and dips, so they don't seem to be a product of earcup reflexions/resonances, at least not always. I'm wondering if the fullrange drivers are the culprit. Even more so looking at the "jaggy" treble in almost all if not all of them. There is a reason we don't have fullrange loudspeaker drivers (at least in Hi-Fi). Then again, implementing a crossover and coaxial dual drivers in a headphone would certainly bring its own problems. Nothing is ever perfect...What I don't get is why are there still hashy narrowband spikes and dips from 1-kHz in a modern flagship when even the HD650 barely has any. Probably not very audible but questions have to be asked about the engineering.
Rather prefer to download the software for free plus s K371 for 130$ than paying 1,600$.Just get an HD800/s and stop guessing.
I have never listened to the Elear. But, if It can be helpful I find the Utopia to be a noticeable upgrade over the Clear (which should be a step up over the Elear)how much better than our "poor old lame" Elear?
