solderdude
Similar-ish response ... sure but they certainly do not sound the same to me and have had the HD650 and Utopia side by side.
Not the new Utopia nor the HD650 with current pads though.
I found the Utopia to have much better detailing and stereo imaging.
In that aspect I found the Utopia to be closer to a well EQ'ed (not Harman, sorry) HD800 in detailing, stereo imaging than the HD650.
The HD650 is no slouch.
That said there are several dB's difference even with the recent measurements in various parts of the frequency range. That IS audible and only says something about tonal balance.
Don't get me wrong, when one is on a budget the HD650 is one of the better options but if one has enough financial leeway the Utopia is the better sounding option to me.
I have to admit there is a slightly weird 'metallic' emphasis on Utopia which works fine with cymbals and strings but it weird in other instruments.
Some prefer this others prefer that. Both the Utopia and HD650 do not follow the Harman curve that closely (I would even say fortunately) and only get decent 'ratings' because there are not so much deviations in the area between 100Hz and a few kHz.
You are correct though that the Utopia is not THE best headphone out there and also has some 'niggles'.
Consider that the HD650 is owned and had been used by Amir for a long time and was one of the first ones he measured/reviewed.
This affects how one rates them.
Pretty certain Amir prefers the Stealth and uses that one most often IF he wants to do headphone listening.
