I went to Focal website and saw the Focal Solo6 Be with grille over the tweeter, both pictured and in the product data sheet:Fascinating! My measurements of the Focal Solo6 Be were a bit different [...]
Yes and the gain switch on the back has a aluminum protection plate around it to prevent it being switched accidentally on some and not others.I went to Focal website and saw the Focal Solo6 Be with grille over the tweeter, both pictured and in the product data sheet:
https://www.focal.com/en/pro-audio/monitoring-speakers/sm6/monitoring-speakers/solo6-be
Obviously the speakers amir is testing have no such thing.
Damn, look at that driver frame! Clearly a lot of thought has gone into minimizing reflections.This is going to be picture intensive but here's some pics. There appears to be different versions from other pics I've seen.
That 2-9kHz directivity decrease is definitely the Focal "house sound", so I don't think they see it as an error.
Yeah for sure. There are at least 3 versions it seems. Just sucks that it's hard to know if the discrepancies are due to the versions, unit variation, or measurement differences.I went to Focal website and saw the Focal Solo6 Be with grille over the tweeter, both pictured and in the product data sheet:
Obviously the speakers amir is testing have no such thing. So it's clear there are different versions.
The "BASH®" circuit uses a high-efficiency, fast-response, pulse-width modulated (PWM) power supply to provide the main voltage rails for a linear class AB amplifier. It varies the output voltage of the power supply in sync with the audio signal being amplified to maintain a constant voltage drop across the output transistors of the amplifier. As a result, the power dissipation (power waste) in the output transistor is greatly reduced compared to traditional class AB amplifiers, therefore the amplifier runs more efficiently."
You mean change the power supply to a PWM switching supply and change the amp section to a class D? Sure if you replace the entire plate amp assembly.Sorry, off-topic funny question. Is this a technique that could be implemented relatively easlily for a hot-running DIY class AB amp? Like replacing the power supply for the output stage with a class D chip amp that is sourcing DC plus a low-pass filtered version of the audio signal on top, something along those lines?
I really love the internals with its good connectors for the cables, shielded transformer and nice clean work. Is this speaker yours?This is going to be picture intensive but here's some pics. There appears to be different versions from other pics I've seen.
No, I googled the speaker and surfed till I found decent pics. Focal seems to be a class act.I really love the internals with its good connectors for the cables, shielded transformer and nice clean work. Is this speaker yours?
I watched an interview with them and they said they put the grill on 40th anniversary. And that the had changed the filtering to compensate. So definitely a different thing even though they claimed they sound the same.I wonder if it has anything to do with the fact that my units had the tweeter grille, although I don't see why that on its own would have such a large effect.
Beryllium is fragile and toxic at the same time.watched an interview with them and they said they put the grill on 40th anniversary.
