Focal Clear Review (headphone)
The original has grey pads.
This is the Focal Clear Professional which is the Clear OG but with different color scheme.
This one:
The Clear MG has a very different color scheme and looks and sounds a little less 'bright' as the original.
The Clear MG Professional and Clear MG are the same but have different looks/color scheme.
how much is "medium volume" What happens at high volume?
The drivers hit maximum excursion. Very obvious and VERY unpleasant.
DT-880 and Clear get about to the same volume for me but the DT-880 fails "gracefully" just increasing distortion.
Clear is completely clean until CLANG! you hit X-max and never saw it coming.
That being said: by the time mine hits X-max, my ears are already experiencing pain, so in practical scenarios this limitation never bothered me.
Clear Professional red pads= Clear OG ?
Focal Clear has:
  • 3m balanced cable (XLR 4-pin)
  • 3m unbalanced cable (1/4" TRS jack)
  • 1.2m unbalanced cable (1/8" TRS jack)
  • 1/8" jack to 1/4" stereo jack adapter
Focal Clear Professional has (aside from different color scheme):
  • extra set of pads
  • 5m coiled asymmetric cable (1/4" - 6,35mm TRS jack)
  • 1.2m straight asymmetric cable (1/8" - 3.5mm TRS jack)
Focal Clear has:
  • extra set of pads
I don't know about the Professional cables, but the ones supplied with the original Clear were dreadful - way too stiff.
I replaced mine with one I found on AliExpress:
Is it possible to download the Focal Clear measurement file to open in REW format?
The Zip file is attached below Amir's review.
You'll have to open it in Excel/Google Sheets and delete the header and export as two separate Left/Right .txt/.csv files, each with Frequency in the first column and dB in the second.
Those you can then drag and drop into REW.
I've been listening to Clear since their release. I've always used the Oratory1990 correction.
I decided to try creating filters in REW. This is what happened. I'll listen to the results.
Filters 5-6-7 could have been omitted to make correction easier.
