- Joined
- Sep 21, 2018
- Messages
- 506
- Likes
- 752
I believe it's more to do with venting than anything else. Most open back dynamics have some sort of front vent whether that be porous pads, porous baffle, or vent holes in the baffle. Open planars on the other hand usually achieve a perfect seal with no vents to be found, since the driver is basically the baffle. There are a lot of closed dynamic headphones which also provide a greater seal and don't feature the characteristic rise in distortion in the bass frequencies. The problem with not venting open headphones is that the lower mids and bass go completely out of control, at least with the couple drivers I've played around with.
Add more rear damping
