This is a review, detailed measurements and listening tests of Focal Clear Pro headphone. It is on kind loan from a member and costs US $1499.
As our British friends say, the Clear Pro "looks the part." It a unique and luxurious design. Comfort was very good although the cups are on the smaller size. The headband spring is quite progressive and gets stiff fast. So if you have a wider head, it may not be so easy to ear.
The standard cord supplied with it is rather thick, short and kind of stiff. Not a fan.
The measurements you are about to see are made using a standardized Gras 45C. Please note that headphone measurements are not very exact so variations exist between reviewers especially in higher frequencies.
Edit: I was told the headphone was the "MG" version. It is not. It is Clear Professional.
Focal Clear Pro Measurements
Let's start with our usual frequency response:
This is almost identical to
Focal Clear I reviewed a while ago. Sadly this means shortfall in bass response and various deviations from 1 kHz up. There was also 2 to 3 dB channel level difference which I could not dial out no matter what I did. Hand pressure on the low output pad would fix this partially but I could not make it do so by itself.
Here is the deviation from the target to use to develop equalization:
Dynamic range and distortion are disappointing at higher output levels. I could easily hear the drivers crackling during 114 dBSPL -- a defect that I have only heard with Focal headphones:
Impedance is highly variable due to a very large low frequency peak:
So if you have a high impedance headphone amp, you are going to get different frequency response than what I measured.
Group delay is messy:
Sensitivity is about average:
Focal Clear Pro Listening Tests and Equalizations
Out of the box lack of bass was obvious and overall sound while not bad, wasn't exciting either. So out came the EQ tool:
It is non-trivial to develop an EQ above bass due to fair amount of variations. I used negative filtering to simplify equalization in the 4 to 6 kHz. The negative filter took down a resonance which improved clarity. And then I boosted the overall region with a more gentle filter. Once there, the sound was transformed substantially and was impressive at times.
The disappointment came from any attempt to push the headphone during bass heavy tracks. The drivers created nasty crackling sound forcing me to turn the volume down. In a sea of competition without this issue, I am so surprised that Focal continues with the same low excursion drivers even with this revision.
At low to medium volumes and with equalization the Clear Professional produces very good fidelity. Turn up the volume or defeat EQ and it becomes a headphone not worthy of the brand. Combine that with the nearly $1,500 price and the limitations become quite glaring.
I personally would not choose or recommend the Focal Clear Pro. But if you like it for some other reason, then be sure to use equalization and keep the volumes down for best performance.
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
