Focal Aria floorstander owners?
im actually curious what people bought AFTER they owned focals. I am experiencing the same thing as many people. at low volumes its nothing to write home about. With spotify its very impressive. But im actually keeping my eyes open for something else, although im lost as to what that might be. I cant say any other speakers come to mind that blew me away. So curious to your experiences...
I tested the 926's back to back against MA Silver 300's, Acoustic Energy AE 509's, Spendor A7's and out of all of those would have kept the 926's as they offered the most detail across the whole range .... BUT ..... I just found them slightly bright on some tracks and a lot of the music I like are older and some of the recordings quite elevated which didn't work brilliantly with them.
In the end I changed them for ProAc D20R's, it wasn't just a case of "done deal", the Focals gave them a very good run for their money and would possibly be better with some songs but the ProAc's were just that smidge better with harsh recordings but they're not night and day difference at low volumes.
Overall I have to say I think the Focals are actually incredibly good speakers but just very slightly bright for my taste / ears.
Thanks for your help.
I understand what youre saying. What some forums said is very true, i dont care what the chart says..these speakers are VERY sensitive to their amp. Doesnt mean you need to splurge thousands on an amp. It just means that you need one that helps the focals to be their best. I noticed with a class d amp they were very harsh on some tracks...then i changed the opamps in that same amp and the harshness was gone. I will try to find an amp like parasound and see how they sound then but i have my eyes open to other alternatives.
This is not a plug and play, be amazed kind of speaker. Right room, right amp, they can be the best youve heard.
Hi all,
I was wondering if there are any owners or people who have experienced testing some of the Focal Aria floorstander range? The 906 bookshelf are very well regarded but floorstanders not as common. There does not seem to be a lot of information on these on english based forums, and I suspect that has do with the large price delta for those outside the EU.
How do these stack up and any stand-outs within the range? I also see they have just released a K2 for the 936. Quick search is putting online prices around the following mark:
Focal Aria 926 - 1450 euro
Focal Aria 948 - 2000 euro (40% more)
Personal context:
I find myself in France at the moment so have some bias towards picking up some local made speakers. I spoke with someone who works for Focal (not a dealer) and said to skip the 936s, go 926 or 948, take that for what it is worth. I currently taking a bit step-up from a Cambridge Audio One system with some small bookshelfs so don't have a lot of reference points at this range.
Did the employee say why to skip the 936?
Its logic, the 926 and 948 are more in balance in regards to amount of drivers. 936 are more emphisised on the lower frequenties which can make them 'boomy' quickly in a not well treated room. I had the 926 and while i sold them because of the metal tweeter not being to my liking, the balance was great. If you want more bass later on its always better to add a subwoofer. 936+subwoofer would be overkill
About to pull the trigger on a Focal Aria system:
2 x Aria 926/936
1 x SUB 1000 F (I know most will advise SVS1000/2000 Pro, but aesthetics commission needs it to match visually)
miniDSP SHD + UMIK-2
Apollon audio 1ET400A ST (purifi eigentakt based amp stable down to 2 ohm!!!)
I intend to make some effort to treat the room, of course only if aesthetics commission approves, and dealing with the rest of it with Dirac/REW
The remaining dilemma I'm stuck with is (given that I'm definitely getting the sub), is choosing between 936/926. Do you speak from experience stating that 936 is overkill? @anotherhobby dit say he preferred bass quality of 936. One point in favor of 926 is the listening height would be closest to my listening position. Room is 55 m².
Edit: note that Focal themselves decided to skip the 948 and not the 936 when they made the K2 limited edition
One thing you will read a lot is this;
Go and listen to the two side by side in a store.
Youre going to spend a substantial amount of money on something you will enjoy for years to come. Are you seriously going to make that choice on behalf of me or any other stranger?
Believe me ive done this myself and sold it with loss many times. Lesson learned.
I had the 926, and heard the 936 and i found the 926 to be more balanced. In your shoes i would go for the 948 without doubt. In france on sale now for bargain.
Secondly, please dont buy a focal sub. There are brands that are specialized in making of subs like rel and svs. Are you the guy that buys a BMW watch of bike just because it says BMW? No, you buy a trek bike because they know that branche.
I would think with properly integrated subs the difference between the 926 and 936 would be pretty small.
of course 936 has stronger bass than 926, but as you are using a dedicated sub, it does not really matter.
for 55m2 you'd need 948, if you want to play music loud enough.
I don't listen that loud, I never exceed 90 dB which should be a breeze for either of these. And my main reason is 948 are just too massive. I'm not even blaming that one on my other half, I've audited the 948 in store but while loving the sound, I don't want it in our living room.
That sale is ongoing for the 926/936 too btw. Problem with store auditioning is: it's not my room. and I won't have my exact front-end gear at my disposal, nor will the sub and speakers be matched using dirac (if there is a sub at my disposal at all). You make a valid point, but in my mind it's nearly impossible to create the conditions where I would be satisfied that the comparison is "valid".
Is your advice on the sub 1000 F based on some experience you had with them? Or if you have measurements at your disposal, please do share because I couldn't find anything online. The reviews that I did find praised it for its precision and accuracy. Maybe I should "distrust" the sub in advance (which I haven't heard either) and just get the 936, giving the sub less work to do? Although I would be surprised Focal are no good at designing them. For one, they have many subs: for cars, home theater and hifi at different price points. I'm not fully on board with that metaphor. If tower speakers are cars, then subs might be more like motorbikes rather than bikes. Which BMW definitely makes quite well, despite any challenge harley davidson might pose ;).
But as I already said: due to the looks (which is something my partner gets a say in) it's gonna be 1000 F or no sub. The aria's themselves (mainly due to the light color and material of the flax drivers) have quite an impact on the look of the family room. Throwing in something like SVS or REL is too much of a challenge for her and, even though I could get over it myself, I get it.
I'd only be getting 1 sub though. But given the similarity between the speakers, one would expect so. Unfortunately, I've never seen anechoic measurements of the 926 (or 936 in fact). Only 936 K2 by audioholics, whhich I'm assuming is pretty much the same given similarity in impedance, crossovers, dimensions,...
Aria 936 and Aria 936 k2 both measured by Stereophile Good luck...
If you like low bass add a sub ;)
I've recently been lookig at Subs as the one for my surround system blew a few weeks ago and whilst replacing wanted to look at if it'd be useful for stereo as well as surround.
From all the research I've done / dealers I've spoken with, the majority of Subs are aimed at the surround market rather than stereo and tend to have more "rumble" which is great for large explosions in a film but not so tight and punchy as is ideal for stereo.
The 2 manufacturers that are more stereo orientated seem to be REL and BKelectonics .... I'll be buying one of the latter at some stage.
Then why the Purifi ?
Looks overkill to me.
Because it´s stable down to 2 ohm (flat frequency response and no load variation in the frequency response) and has very low sinad. I can keep that thing for as long as it doesn´t die on me, because upgrading just makes no scientific sense.
And even if it dies on me I could easily replace the smps, opamp or amp modules themselves. It´s reference grade stuff delivered at my doorstep for 1365 euro. It kills the fear of missing out that would otherwise haunt me a month after I´ve bought some "reasonable" thing.
Interesting. Hadn´t heard of BKelectronics yet. I also heard that a sealed sub is generally going to sound more audiophile. Not sure if there´s any truth to that, but let´s not go off topic too far.
I´m getting the sub 1000 f to go with the focal 9X6. I´ll be sure to report my findings. Kind of surprised that I didn´t see anything on that combo in this thread (unless I missed it).
