This is a review and detailed measurements of the Focal Aria 906 Bookshelf/stand-mount speaker. It was kindly purchased by a member and drop shipped to me. I think it costs US $2000 for a pair but I see it on Amazon including Prime shipping for half that at US $999. Better yet, they have a $100 discount coupon right now bringing the price down to $899! For a French manufactured speaker from a top brand, this is an excellent price.
What's more, the color and style is gorgeous to look at:
The woofer is made out of the fibers of flax seed. Yeh, the same stuff health food people put in smoothies and such. Apparently France is the #1 exporter of Flax seeds. It does give the speaker a very modern and nice look. As does the leather baffle, very nicely down vinyl wrap and glossy top. The port looks a bit cheap but that's it.
Back panel has custom binding posts with plastic handles which I have not seen before:
My overall impression is very positive seeing how they matched the color of the cabinet to that of our forum! We must have similarly good taste.
I used nearly 1000 measurement point which produced a very accurate grid for sound field prediction, indicating a clean response form the speaker at high frequencies.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker can be used. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
I always look at at the response up to 1 kHz first and there, the 906 is doing a very good job. There is a bit of peaking around 800 Hz but it is minor. Above that, we have a broad dip and some directivity error but in grand scheme of things, this is good response.
Early reflections has a similar dip:
Ceiling and floor contribute the most to that dip so if you absorb them, it should reduce their impact. The "front wall" (your back wall) helps in this regard so don't try to absorb that.
Predicted in-room response which is the sum of what we have already seen presents a good picture:
Overall signature then should be more or less neutral which is what we want out of a speaker.
Listening window is wide and smooth to -6 dB level:
So you don't have to worry too much about exact toe-in. And the room sides will be illuminated with response that is close to direct sound.
Similar view exists in directivity plot:
Vertical is chewed up as it typically is:
Focal talks a lot about the reduction of woofer distortion through its construction and seems like there is something to that if you keep the levels low:
Compare this to a studio monitor I recently reviewed:
In absolute levels we get this:
I like to see nothing peaking above 500 Hz or so and we are almost there at 86 dB.
Trying to find the source of that, I made a near field measurement of the woofer:
Looks like break up modes are way above the 1 to 2 kHz where we see the distortion.
Here is the port response:
This is showing the issue but I am thinking it is the tweeter that is breaking up there. Open to other suggestions.
Here is our waterfalls for fans of this graph:
Finally, some of you keep asking for phase response. Here it is:
Edit: adding the impedance graph:
Subjective Speaker Listening Tests
I always observe how a speaker sounds the moment I turn it on. Here, the 906 did well! It sounded warm and nice with fair bit of detail.
Further listening showed a bit too much bass so I went after correcting that 800 Hz peak and boosting some of the dip:
The tonality improvement with the 800 Hz was very welcome. And positive across all content.
The fix at 3000 Hz made things brighter in a good way for most content but not all.
At this point, I sat back and enjoyed the speaker. It was a delight to look at and very nice to listen to. Here is a sample track from my reference list, Allan Taylor's Let The Music Flow (sounds awful on youtube):
I was able to play quite loud without causing the 906 to fall apart. Credit for this is the speaker not attempting to play too low and hence be able to get loud without severe distortion/bottoming out. As a result content with deep bass doesn't sound as full. It is a much better fit to content like above.
The Focal Aria 906 is gorgeous to look at and comes at a very low price for a French made speaker from a top brand company. It only has small imperfections and seemingly low distortion, making for a very pleasant and nice speaker to listen to with a bit of EQ.
Overall I am going to recommend the Focal Aria 906.
Would be interested to know what it goes for in EU market. If it is similar to US discounted pricing, it should provide a great option for our European members that have trouble getting access to American brands.
Given the nice sound of the Focal 906, I am thinking of growing some speakers in my yard. Flax seed is easy to get. Wonder what fertilizer I need for the plant to produce woofers. No doubt I would have to import some secret sauce from France which won't come cheap! So please donate what you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
