Foam mattresses for room corrections ?
Hallo everybody.
I hope that you have survived the summer heat !
This summer during the heat waves, my hifi room has not advanced
much and now I have to leave to work and will only have time starting
in December doing my first REW reading, of course,
before
setting up any room corrections.
Foam in speakers is common but what about my accumulated
6 foam mattresses I have in my garage. I was going to take them
to the recycling yard since no one wants them even for free,
but now I thought about room acoustic treatments ?
Good idea or Bad idea ?
I could put them behind the speakers, behind the listener,
and a beautiful curtain in front to hide them.
So what about these mattresses ?
Are they any good for room corrections
or should I just take them to the recycling yard ?
Thank you so much.
Once you start making measurements, you could be the one showing the measurements, telling us how they are working in your room.
Us knowing nothing about your system and environment, you'll just have to measure with them in different configurations, and see if your room acoustics can be optimized with them. You can always throw them away later...
Acoustic foam has smallers cells then mattresses and it has a longer lifespan to.
But try and see where you end up
Just for your possible interest and reference...., my post #498 on my project thread. :D
Consider collecting another 50 or so mattresses, and fill the lounge from floor to ceiling to get zero room effects :)
Or a trip to the tip is the right thing, but have soft, non-mattress furnishings in the room instead - sofas, rugs, rugs on walls, book cases etc.
Other will say you just need EQ.
Hallo everybody.
before
Thank you so much.
As long as they are dry and clean. :) How thick are they? If you're going to use them for sound absorption—not for bass—they need to be reasonably thick to have any effect.
One thing you can do is ask a friend to move a mirror along the side walls. When you see the speaker in the mirror from your listening position, that’s where the first reflection occurs. Place mattresses there on both side walls. See whether you prefer the sound with them there versus having bare side walls.
If you want to keep them there permanently, I would cover them in a fabric with a pattern that matches your décor.
That’s actually what I’ve done with a mattress I keep behind my sofa (which is positioned flush against the back wall—I can't really arrange the furniture any other way).
If you have large windows, try using sound-dampening curtains. I’ve seen stylish, affordable ones on Temu. I haven’t bought any myself yet, though, so I can’t vouch for their quality.
Exactly, and since @RaymondFromThePyrénéés has them anyway, he can experiment a bit. :) They don't have to be installed permanently.
However, I would consider the overall look—furniture, rugs, and so on. After all, it needs to be both aesthetically pleasing and functional in a room that serves as both a living room and a listening space. Slapping mattresses onto various walls could easily undermine that—at least the aesthetic aspect.
Mattresses are available in different density classes. A highest density foam mattress is pretty heavy.
No idea how it compares to accustic foam though. Or if they offer themselves to be recycled into basstraps.
I think it's at least worth trying them out and doing measurements.
I think you could theoretically make a VPR bass trap by gluing a ~1mm steel sheet to a mattress. That would be pretty interesting.
They will do something. Whether they do what you want is another matter. Since it costs you nothing, you may as well try it and report back.
We recently bought a Tempur Soft mattress and it's excellent. I'm thinking of nailing my speakers onto the ceiling and just staying in bed. Plus, I'd get free "height" speakers as part of the deal.
Bass traps for the really low frequencies? I wouldn't think so. Here is what Amir writes about it in another thread, posts #598 and #618:
And as a bonus, you can sleep standing up!
View attachment 560191View attachment 560192
You have to turn it into a pressure trap vs. velocity to work on bass, which is why I suggested making VPRs.
