In a way that is funny to me because all of Schiit's "R2R" DACs use chips not even designed for audio but rather for instrumentation. They have objectively pointed out issues in both distortion, IMD, ... just overall not a top performer. They could actually tweak the chips to be more suitable for audio using de-glitching tech. But they choose not to and just use them as-is, with all flaws in tact.
So forgive me being sceptical about these specialised, non-audio Analog Devices chips somehow producing a "timbre" not found in IC chips actually
purpose-made for audio. You're not hearing a more natural/real/timbre-precise sound. Do you think the people producing and mastering music are listening to these flawed distortion machines? How could one then think that the Yggy is more truthful? I think a proper volume matched controlled listening test would surprise you with the differences you now think are so clearly there.
https://www.stereophile.com/content/schiit-audio-yggdrasil-da-processor-measurements
"the overall shape of the reconstructed sinewave is good [...]but you can see
significant errors at the signal's zero-crossing points"
"the Schiit
clipped with signals higher than –10dBFS into the punishing 600-ohm load (fig.9). I then tested the Yggdrasil for intermodulation distortion with an equal mix of 19 and 20kHz tones (fig.10), and while the actual intermodulation products were between 90 and 100dB below the signal's peak level, the noise floor again looked ragged"
"It's difficult to sum up the Schiit Yggdrasil's measured behavior. While the processor's analog circuitry is superbly well designed, its digital circuitry appears to have
problems with high-level, high-frequency tones, and with the LSBs of 24-bit data".
Yeah, what a great DAC...
