Fluid C35BT Budget Monitor Review
Rate this monitor speaker:
    Votes: 24 17.0%
    Votes: 73 51.8%
    Votes: 41 29.1%
    Votes: 3 2.1%
My earbuds can "can actually put out an impressive amount of bass for [their] size until run into [their] SPL limitations."
I'm unclear what the point of this remark is supposed to be. Your earbuds are fit for purpose, I presume?
Or your eardrum limitations, when someone needs to put out an impressive SPL for you to even begin to hear ;)
-8 dBu represented 91 dBSPL. I added 5 dB to that for -3 dB and that is when the input overloaded. I did not try to find another level that didn't.
So the input can barely take half a volt, if that. That's pretty naff. You could overload this one with any random onboard audio. I assume that you were using the unbalanced input? I would very much hope that the balanced input has a bunch of negative gain under these circumstances. I won't be surprised if they were going for -10 dBV / +4 dBu...
Any comparisons to the "Vulkkano pro4"?They sound significantly better than the Edifier M4. I don't know how they compare to the fluid-c35bt.Any opinions?
