Fluid Audio FX50 Review (Active Speaker)
Same price (150 usd each), no brainer.
Here's another pic of the tweeter assembly showing it is mounted in front of the woofer. The front view of the speaker makes the tweeter appear as if recessed inside the woofer. I was wondering how Fluid Audio could afford to put a tweeter inside the woofer assembly and now it make sense how they budgeted the design.
I actually thought it is a Kef style coaxial
So did I and then I thought about the retail price of the speaker and realized the budget just isn't there for KEF style engineering.
@amirm How can we know which version we're buying? Is there a physical or labeling difference that will distinguish them apart?
Actually I was a bit puzzled, it seems both put the tweeter in where the dust cap of the woofer should be, so why mounting the tweeter with its wave guide inside be more challenging than putting it in front ?
Putting it inside the center of the woofer means the entire tweeter magnet assembly has to go inside the woofer assembly too. Very complicated stuff. Is that what you meant.
Yes, that solved my question, I didn’t thought of the magnet assembly interference stuff
There isn't any. Company told me from serial number they can tell if it is new or old. I gave them mine and they said it was old. If you are going to buy them, I would contact them and ask which serial numbers are the newer revision.
Hi,
Here is my take on the EQ.
The raw data with corrected ER and PIR:
Score no EQ: 2.88
With Sub: 5.30
Spinorama with no EQ:
  • Plenty of resonances
  • On compromised by the coax
Directivity:
Better stay slightly off axis about 10deg in any direction if no EQ
Maybe better On axis with EQ
EQ design:
I have generated one EQ. The APO config files are attached.
  • The EQ is designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment
  • I have added the EQ devised by @amirm for comparison
Score EQ Amirm: 3.57
with sub: 6.00
Score EQ Score: 4.74
with sub: 7.10
Code:
Fluid FX50 APO EQ Score 96000Hz
January292021-161938
Preamp: -3.4 dB
Filter 1: ON HPQ Fc 30.7 Hz Gain 0 dB Q 0.88
Filter 2: ON PK Fc 106 Hz Gain -4.25 dB Q 1.44
Filter 3: ON PK Fc 1006 Hz Gain -3.7 dB Q 4.28
Filter 4: ON PK Fc 1668 Hz Gain -3.4 dB Q 6.29
Filter 5: ON PK Fc 2480 Hz Gain 4 dB Q 3.06
Filter 6: ON PK Fc 5997 Hz Gain 3.5 dB Q 5.07
Filter 7: ON PK Fc 7308 Hz Gain -2.72 dB Q 0.83
Spinorama EQ Score
Spinorama EQ Amirm
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
The rest of the plots is attached.
  • Fluid FX50 APO EQ Score 96000Hz.txt
First of all, great acknowledgement goes to another cooperative/supportive manufacturer.
Secondly, dimensions being one of its main advantage, I can imagine scenarios where people want to "embed" these in tight spaces in their home environments, when speakers have to follow existing furniture setup rather than other way round. (shelves with no modularity, corner PC desks..)
Dimensions comparison with some 5" monitors reviewed (also, the depth of FX50 can be taken as "definitive", versus rear ported models..) :
H W D [mm]
234 176 230 Fluid audio FX50
298 179 297 Adam T5V
298 185 231 JBL 305P MkII
285 170 222 Yamaha HS5
Dang, KH80 is tiny. Maybe that visual aspect is in part why Amir said they sounded small.
Anyone know any AR phone apps where you can make 3D shapes to display?
B&O actually has full 3D AR models of their speakers so you can see how they look in your room. It’s fully fledged too, any reflective finish will reflect the surroundings in your room.
EDIT: I found some, but mostly not intuitive or not easily creatable.
There are quite a few, but ... idk, maybe I haven't tried the right one, but I haven't been too impressed yet.
Kinda works, but it's not great. Making a template out of cardboard works better imo.
