- Joined
- Mar 29, 2021
- Messages
- 2,404
- Likes
- 4,154
I think that is a fair point, and it is safe to assume design engineers have not forgotten to consider what happens when the load reactance increases, and that we should not be worried the amp will explode just because the phase response of the headphone we have connected to its output is a bit wonky. I also suspect the effect of that on distortion and frequency response would be limited for some amps, but maybe not so limited for others? As you nicely explained, amps usually overshoot with reactive loads, so maybe that effects tonality? If we took two amps people claim sound different, measure distortion and output levels across the frequency range for a number of different headphones some of which have low phase angles within 20-20K range, and close this topic once and for all, that would be great in my opinion.But, these effects are well understood by both amplifier and speaker designers, and competent ones are sure to take appropriate steps to ensure we as consumers don’t run into trouble when we wire them together.
For what tests you'd like to see, I actually gave this some thought and had a running list, but the more I went into the details of the data Amir publishes, the more I was able to figure out what I wanted to know. For example, I wanted to see THD% vs Frequency at two output power levels; at 0.05mW and max rated power, but then we already have THD vs power graphs so that would probably be redundant. Might still be useful to have see such a graph though if it is easy to do with the AP equipment, as at least it would make the arguments about about amplifier tonality harder to argue. I don't know what exactly are the mechanisms that are suggested by those who claim amps have tonality so would be good to get some input from that side as well.
One thing is not clear however, I hear people talk about transient power, especially in relation to low end, and I am not sure if any of the measurements in the current measurement suite cover that. If not, would be good to have one to get an idea whether amps behave differently at different output power levels for transients.
Just to share, I wanted to see if I can find out what would be the THD% for AK371 at normal listening levels for A30Pro and RME ADI-2, both of which are very realistic scenarios I believe, especially for this forum, given how highly Amir rates these products. If my graph readings are not incorrect THD% for A30Pro is around -85db and around -81db for RME (HPA side only). Very respectable, but not 120db. I don't know if this makes them transparent or not but 85db is less than 16 bits, so maybe cassette people were right all along
