Hey everyone! I have some technical questions and really could use some help figuring out my issue. Along the way during my audio journey I decided I wanted some expensive speakers for a change (because that means they're good right?), but because I couldn't afford them I decided I would go the DIY route. I had someone design the speaker for me, and build and test the crossover. I spent a large chunk of last year building them, put my heart and soul into the build, and they look gorgeous but out the gate didn't sound right.
Either way I played with the eq at the approximate crossover points and I really think it's just a matter of the tweeter and midrange are just too high. After shelving the mid 4db down, and the tweeter 2db down, they sound pretty damn good. I did some in room measurements, and compared them to Elac DBR, which is properly balanced as per Klippel, and there is definitely too much energy above 400-500hz. I wan't to measure the speaker as objectively as possible and fix it at the crossover level. I don't know what the actual crossover points are, but I am waiting for a response from the designer. Also, I don't care about the added bass from what I want to do, as I can use room correction to fix that.
I just have a couple of questions.
1. Due to the driver layout I am having a difficult time doing quasi anechoic measurements. The bottom woofers proximity to the floor is making gating an issue. I don't really care about getting a detailed measurement, as I am just interested in getting an accurate relation between the mid and woofer levels. Is there an accurate way to measure this? Would close micing the woofer (+adding 3db for second woofer), give me an accurate spl in the 200-1000hz range? Any other suggestions?
2. The horizontal on and off axis are really good on this speaker. The dispersion mismatch is minimal below the tweeters omni directional point. Would dropping the relative levels between drivers while keeping the same crossover points have a massive adverse effect to my on off axis uniformity?
I really want to keep these speakers. I put way to much effort, money and time into them, and I love how they look. Any advice would be much appreciated.
Thanks!
Thanks!
