- Thread Starter
- #21
Speaker to side wall = 0.95
SBIR cancellation frequency = 0.95m x 4 = 3.8m
That equals 90Hz.
The problem with speaker placement is that there is no perfect position, only the least compromised positions. This is particularly true for smaller rooms. If you were to push your speakers so close to the wall that you eliminate this SBIR cancellation, you would screw up central imaging by widening your listening triangle. Another option is to position your speakers asymmetrically in the room so that the SBIR frequencies do not coincide. But if you do that, the upper frequencies will also have asymmetric reflections, and it will screw up imaging.
Another option is to get a subwoofer and cross it over at about 100Hz. You will need a bit of DSP to get it to blend in though. It may be best to try to lower that frequency so that you don't have to run the sub so high.
No. Any speaker placed in the same location will have the same problems below the Schroder frequency, assuming the frequency response is the same. The reason you buy a KH310 is because it's not as lumpy at the top end as your Yamaha.
That eBook is not a complete manual on acoustics, but it will be enough to get you started. You will still need to buy and read an acoustics text like Toole or Everest if you want to fully understand the subject. And BTW I never wrote that book with printing in mind, most of those diagrams rely on colour to make sense.
I can try positioning, pushing them forward and also moving myself forward with the seat so the triangle is the same, that should keep the stereo image the same, shouldnt it?
I get it, but meant more of will the DSP room correction provided by Neumann be able to resolve it or its just a guessing game?
Printed it in color
