I have asked a mod to split your old thread and merge it with this one, so all the replies don't get lost.
Before we go any further:
1. Please read this thread:
How to ask for help with REW in ASR
2. Your five files have duplicate measurements. In the future, delete all duplicate measurements and only post relevant measurements.
3. Give your measurements proper names. All I know is that it's L and R. Any subwoofers?
Since you asked about how to improve your room, the relevant measurements are the last three files which contain timing information. MMM measurements can't be used to look at the room. Of the 18 measurements you posted, I threw away 16 of them. Here are a couple that I threw away:
What is going on here?!?!? I am guessing that these are L/R speaker MMM's taken at 75dB and 80dB. They are very different to your single point logsweeps. So these are clearly nonsense measurements, they need to be thrown away. If it looks strange to you, delete them and try again.
Red/Blue = left/right speaker. Yellow = L and R speaker measured together. Notice how the combined measurement has a treble boost from 6kHz up (circled). This measurement is clearly flawed and should be rejected.
As I pointed out in my post in
the other thread, comparison between your measurement and published measurements of your speakers suggests you have a huge cancellation between 55Hz - 110Hz. This is normal for all speakers in all rooms, but you may be able to improve your situation by repositioning the speakers or listening position, or both.
If we look at your RT60 (here, only the right speaker) we see that your RT60 is on the "wet" side above 100Hz. Read more about the RT60
here. For a very small room like yours, these are not true numbers since these are specular reflections and not reverberant fields.
The interesting thing is - it really shoots through the roof below 100Hz. If you see this, we normally think "room mode". But with a room mode, you expect to see a big spike in the freq response graph at 50Hz (since that is where the RT60 seems to peak). But in this case, there is no spike in the FR graph. So why is there so much "reverberation" at 50-60Hz?
Answer: poor signal to noise ratio / high noise floor. This is your waterfall graph, which I extended to 1000ms and ticked the "normalise to peak at each frequency" option. It is likely that if you chose a quieter time to measure, your "RT60" will improve.
There are some good things though. Your Energy-Time Curve (ETC) shows there are no reflections louder than -15dB in the first 20ms. Probably because you are sitting so close to your speakers.
