First review of GGNTKT’s M1 loudspeaker
Purité Audio
Industry Insider
Barrowmaster
London
Morla
Europe/Germany
mouth-watering.. too bad the switch from passive to active with dsp also means you suddenly have spare parts to sell and you buy those parts again but integrated now.
Also in the review they use the analog output of the rme to feed the gegentakt while it has AES input. Not clear to me if the analog path circumvents the internal dac since I would assume the DSP is always in the path after all. Clearly it should be given digital input for best results, no?
McFly
NZ
Neat. Sort of another D&D 8C? Cheaper too.
Daverz
I like the modular design that allows for the simplified wiring of the speakers.
groovybassist
Wendell, NC
Great review and actually a perfect design for my living situation, but...a wholesale rewrite of my system and current direction.
HiFidFan
U.S.A
About $6k/pair, including sound processor & amplification?
Me likey
dwkdnvr
Hmm, I'm seeing it as an extension of the Grimm LS1 idea. Front-firing the 2 are basically the same - wide baffle + waveguide to provide control down to ~250Hz. The extension here is to use the rear-firing woofers to extend the directivity control lower. You're correct that the ultimate effect is closer to the cardioid response of the 8C, but the technique to get there is much different.
Very interesting, indeed.
McFly
NZ
KEF better get a move on, they have the gear (LS50W) and the foundation for an Active cardioid R3 that could be a world beater.
LearningToSmile
Very nice. Quite curious about their M2 model, but it's still just "coming spring 2021" on their website.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I believe they are close,
roland{at}GGNTKT
Germany
I can add two more reviews, but it's all local press:
